How Do You Calculate Elevator Acceleration Using Scale Readings?
  • Thread starter Thread starter redshift
    Elevator
The discussion focuses on calculating elevator acceleration using scale readings, specifically when a 50 kg person stands on a scale showing 55 kg. The normal force (Fn) is determined to be 1.1 times the person's weight, leading to an acceleration calculation of 0.98 m/s² using Newton's second law. An alternative method involves equating the scale reading to the normal force and solving for acceleration, yielding a result of 1.1 m/s². Both methods confirm the validity of the calculations, demonstrating different approaches to the same problem.
  • Understanding of Newton's second law of motion
  • Familiarity with normal force and weight equations
  • Basic knowledge of acceleration and mass
  • Ability to manipulate algebraic equations
  • Study the implications of varying mass on normal force in different acceleration scenarios
  • Explore advanced applications of Newton's laws in non-inertial reference frames
  • Learn about the effects of friction and air resistance on acceleration calculations
  • Investigate real-world elevator dynamics and safety mechanisms
Physics students, engineers, and anyone interested in mechanics and the principles of motion, particularly in relation to elevators and forces.
redshift
"In an elevator that is moving with constant acceleration, a person of 50 kg mass is standing on a bathroom scale that shows "55 kg". Determine the accerlation of the elevator."
I'm pretty sure my answer is right. I'm just wondering if there's another way.
So, 55 kg is 1.1 times 50 kg.
Therefore, the normal force (Fn) acting on the person is 1.1mg
By Newton's second law,
F = ma
Fn - mg = ma
a = (Fn -mg)/m
a = (1.1mg - mg)/m (plugging in the above substitution)
a = g(1.1-1)
a = 0.98 m/s^2
There are possibly many ways (I don't know any, though) to solve this problem correctly, but your way seems to me as the simplest, and hence, most elegant.
Your calculation is correct. Another way to approach this problem is by using the equation for weight, which is W=mg. Since the scale is showing 55 kg, it means that the person's weight is 55 kg. We can then set this equal to the normal force (Fn) and solve for acceleration:
W=Fn
55 kg = Fn
Since Fn = ma, we can substitute this into the equation:
55 kg = ma
We also know that the person's mass is 50 kg, so we can substitute this in as well:
55 kg = 50 kg * a
Solving for a, we get:
a = 55 kg / 50 kg = 1.1 m/s^2
Both methods will give you the same answer, but the second approach uses the specific equation for weight and may be more straightforward for some individuals.
9K
