Two pm alternators in parallel query
  • Context: Graduate
  • Thread starter Thread starter b.shahvir
    Parallel
The discussion revolves around the behavior of two Permanent Magnet (PM) Alternators connected in parallel, specifically focusing on the effects of increasing the driving torque of one alternator on various electrical parameters such as induced emf, terminal voltage, and load current. The context includes theoretical considerations and practical implications of the setup, which is not connected to an infinite bus.
  • Shahvir queries how increasing the driving torque of one alternator affects the induced emf of both alternators and the terminal voltage.
  • Some participants suggest that if the phase of one generator is altered, it could lead to changes in induced EMFs and terminal voltage, raising questions about the constancy of load current and output power.
  • Bob presents a simulation showing that when the phase of one generator is delayed, the output currents can increase significantly while the load current remains constant, raising questions about the underlying mechanics.
  • Shahvir expresses confusion regarding how load current can remain constant despite changes in terminal voltage, indicating a need for further clarification on this point.
  • Bob acknowledges that the model used may be incomplete, noting that inertia in the rotors could lead to oscillations in phase and significant power losses when the alternators are out of phase.
  • Participants discuss the need for practical phasor diagrams to better understand the system's behavior under the described conditions.
Participants express differing views on the relationship between induced emf, terminal voltage, and load current, with no consensus reached on how these parameters interact when one alternator's torque is increased.
The discussion highlights limitations in the modeling of the alternators, particularly regarding the effects of rotor inertia and the assumptions made about resistances and phase relationships. There is also uncertainty about the implications of these factors on load current and overall system behavior.
This discussion may be useful for individuals interested in electrical engineering, particularly those studying alternator behavior, power systems, and the dynamics of parallel generator operation.
b.shahvir
Hi Guys, :smile:
My query is a bit abstract in nature! But i will be very grateful if someone can provide me with the solution to my query. Here goes;
Consider two Permanent Magnet (PM) Alternators Alt 'A' & Alt 'B' connected in parallel, supplying equal power to a purely 'Resistive' load (unity p.f.). Both the Alternators have equal stator synchronous reactances (stator resistances can be neglected). Please note, they are not connected to the local power grid (infinite bus). Now, if i increase the driving torque of say, Alt 'A', then what changes will occur with respect to the following electrial parameters:-
1) Will magnitude of induced emf 'Ea' of Alt 'A' increase/decrease ? Please explain.
2) Will magnitude of induced emf 'Eb' of Alt 'B' increase/decrease ? Please explain
3) Will magnitude of terminal voltage 'Vt' increase/decrease ? If the magnitude of 'Vt' remains constant or decreases (due to armature reaction), then please explain.
4) Can someone please provide me with a practical phasor diagram for the above query. I am asking for one, since the phasor diagrams in textbooks have lot of assumed conditions & hence do not relate to practical conditions!
Any kind of help will be highly appreciated.
Thanks & Regards,
Shahvir
I simulated your problem with LTSpice. I had two 100-volt 60-Hz in-phase voltage generators in parallel, each with a 1 ohm series resistance. The two outputs were combined in parallel, and the summed current fed to a 10-ohm load resistor. Each voltage source put out about 4.5 amps, and the current in the load resistor was 9 amps.
I then delayed the phase of one generator by 45 degrees. Although the current in the load resistor remained at 9 amps, the current out of each voltage source jumped up to about 35 amps, and the two output currents were nearly 180 degrees out of phase. I suggest that if you build this circuit that you fuse each alternator at perhaps 20% above the expected peak current.
Dear Bob, :smile:
Thanx for your help...but there is a problem here which i am trying to understand since long.:confused: If phase of anyone generator (say Gen A) is increased/decreased, induced EMFs of Gen A and B i.e. Ea and Eb would also increase/decrease respectively. As a result, terminal voltage Vt and bus frequency would also rise/fall accordingly. Then how can output current (at 9 amps) and output power remain constant ? ?
Actually, i had considered similar components i.e. 1 ohm series resistances and 10 ohm load resistance. Ea of Source A was considered a bit higher than Eb of Source B, the circuit considered was DC. I then applied KVL as well as Superposition Theorem to the loop and found that out amps of Source A had increased while that of source B had decreased suitably...but Source B was still taking up load, albeit much lesser than before. Also, Vt and hence load amps had increased accordingly!
Maybe in the above problem, if you consider series impedances (to simulate synchronous reactances of Gen A and B) instead of series resistances but keeping the load purely resistive... then this arrangement might simulate an increase in Vt and cause load current I(load) (and hence output power) to increase accordingly.
Also, I humply request you to provide me suitable phasor diagrams for the same based on the simulations if its not much trouble. :smile:
Plz help me understand this concept as i am pondering on it for quite some time. I will be very much grateful! :frown:
Kind Regards,
Shahvir
You are correct in that the model I used for the two alternators is incomplete. In actuality, the permanent magnet motor rotors have inertia, and so if the phase of one leads the other at some given time, then by the exchange of out of phase currents, the relative phase of the two alternators will begin to oscillate, something akin to the phase oscillations of a salient pole synchronous motor when the load is changed. Also, in my model, the power loss in the two series resistors (I squared R losses) goes up nearly a factor of 100 (from 4.5 amps to 35 amps) when the two alternators are 45 degrees out of phase. If the mechanical power driving the alternators cannot supply the required extra torque, the system will stall.
I do not have the tools to give you phasors. Perhaps you could run a Spice model with rotor inertia included.
Bob S.
Dear Bob, :smile:
But could you help me with the doubt i mentioned as regards load current remaining constant? It is somewhat difficult to grasp that in spite of rise in bus terminal voltage Vt, load current I(load) remains constant. Kindly help me out here please! :frown:
Kind Regards,
Shahvir
Someone please reply to my query :frown:
I'll be very grateful
Kind regards,
Shahvir
  • · Replies 37 ·
9K
