Register to reply
Calculate Values of L and C
by wayneinsane
Tags: values
Share this thread:
wayneinsane
#1
Mar22-09, 02:27 AM
P: 16
An RLC circuit has a resonance frequency of 2000/pi hertz. When operating at angular frequency w > w0, reactance of inductance is 12 ohms and reactance of capacitance is 8 ohms. Calculate the values of L and C.
2. Relevant equations
XL = wL
XC = 1/wC
3. The attempt at a solution
welll, what i thouht was w = resonance frequency which is 2000/pi hertz... so since XL is given (12) and XC is given (8), then I plugged in the numbers and got this.
2000/pi = 636.6 hz...so, XL/w = L
12/636.6hz = .0188 H = L
and, 1/wXC = C which is 1/(636.6)(8) = .000196F = C
Correct or not? I feel like something is missing!
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Kruum
#2
Mar22-09, 04:54 AM
P: 220
Your answer isn't correct. There are a couple of things you're doing wrong. First of all, frequency isn't the same as angular frequency. And second, you're calculating the reactances of L and C using the resonance frequency, when values are given with higher frequency in the problem. You'll need three equations to solve this one, you've got two of them. Do you have an equation for resonance frequency or can you perhaps derive it with the knowledge you've got?
wayneinsane
#3
Mar22-09, 10:52 AM
P: 16
But isnt w the symbol for resonance frequency? and resonance frequency is given in the problem, along with the reactance of capaciatance and inductance...im not sure what other equation I would need..
Kruum
#4
Mar22-09, 12:07 PM
P: 220
Quote Quote by wayneinsane View Post
Nope. The w is the angular frequency (i.e. how fast sinusoidal signal goes through one cycle), the angular frequency for the resonance frequency is usually denoted by w0. There is link between angular frequency and frequency, though. [tex] \omega=2 \pi f[/tex]. When RLC circuit resonates, XL-XC=0. You can derive the third equation from that.
wayneinsane
#5
Mar22-09, 03:44 PM
P: 16
Hmm, this is starting to make sense... I just checked my notes and you are absolutely right. Wo is the resonance frequency...
so.... since w = 2 pi f, and XL = wL... can I do XL = 2 pi f L which would be XL/2 pi f = L, so 12/4000 which is 3 x 10-3...
then, for XC = 1/wC, can I do XC = 1/2pi f C, which would rearrange to C = 1/XC 2 pi f which would be 1/8x4000 which is 3.125x10-5...
correct?
BTW, thank's a lot!
Kruum
#6
Mar23-09, 06:06 AM
P: 220
Still not correct. Seems like my earlier point didn't go across the way I meant. This sentence "When operating at angular frequency w > w0, reactance of inductance is 12 ohms and reactance of capacitance is 8 ohms." says, that XL is 12 ohms and XC is 8 ohms at some unknown frequency, that is higher than the resonance frequency. So you can't use the resonance frequency to directly determine L and C, like you are now trying to. Solve XL-XC=0 as a function of L and C (i.e. isolate the w to one side and the rest to the other) to get the third equation. From there you can solve the frequency that makes XL 12 ohms and XC 8 ohms.
Register to reply
Related Discussions
Questions about expectation values and definite values (quantum physics) Advanced Physics Homework 3
Exact Values of Trigonometric Values General Math 0
Use the experimental values to calculate the enthalpy change in the system. Biology, Chemistry & Other Homework 1
Calculate the formula weight for values of X Biology, Chemistry & Other Homework 1
Binomial Theorem - small values of x and approximate values Precalculus Mathematics Homework 7
