[Q]Queation about Photon and Electric discharge.
The discussion focuses on the behavior of photons with energy exceeding the difference between adjacent energy levels in atoms and the process of dielectric breakdown in gases under high voltage. When a high-energy photon collides with an atom, it can either transfer excess energy to the kinetic energy of an ejected electron or remain unabsorbed, depending on the material's properties. In the case of dielectric breakdown, increased voltage enhances the probability of electron movement between electrodes, leading to ionization of the gas and a decrease in resistance, which is critical for applications like fluorescent lighting.
  • Quantum mechanics fundamentals
  • Understanding of photon energy and atomic energy levels
  • Knowledge of dielectric breakdown phenomena
  • Basic principles of ionization and electrical conductivity
  • Research the principles of ionizing radiation and its effects on atomic structure
  • Study the mechanisms of dielectric breakdown in gases and its applications
  • Explore the relationship between voltage, current, and resistance in electrical circuits
  • Learn about the properties of materials that affect photon absorption and transmission
Physicists, electrical engineers, and students interested in quantum mechanics and electrical phenomena will benefit from this discussion.
good_phy
Hi, I just wander what hapeens if photon which energy is higher than difference of adjacent
energy levels collide with atom? How does Excess energy go? transmiting atom by form of
photon or giving motional energy to the atom?
Second Question is What does process ocurrs when enough voltage to make dielectric
breakdown imposes to gas?
I know electric force imposing positive and negative charge 'tear' atom and separate
opposite charge, but in aspect of energy, just another external potential is added to the
atom and i can't image tearing atom in this view.
How can you explain tearing atom with aspect of energy, not force?
Depends on what kind of transition you're talking about. E.g. if you're talking about ionizing radiation, which ejects an electron entirely, then surplus energy can go into the kinetic energy of the electron, which is continuous once the thing is free.
But in most cases, the photon simply won't be absorbed. Just look at some transparent material like glass, which will absorb most IR, but is transparent to visual light which is higher in energy.
Well, force and energy are always related. But what happens is that, between your two electrodes, you always have a probability the electrons will fly across space from one to the other. The higher the voltage, the higher the probability that will happen. For low voltages the probability, and thus current, is practically zero. But once they do start flying across, they hit and ionize the gas (ejecting electrons) which in turn makes it easier for other electrons to pass. In other words, the relatively unusual situation that resistance decreases with current. (Which is why fluorescent lights need an electrical ballast)
  • · Replies 29 ·
  • · Replies 46 ·
