The Force Between Current-Carrying Conductors
  • Thread starter Thread starter vrobins1
    Conductors Force
The discussion focuses on calculating the force between two parallel current-carrying conductors, each carrying a current of 2 A and placed 1 m apart. The magnetic field (B) generated by one conductor is calculated using the formula B = μ₀I/2πr, resulting in a value of approximately 3.95 x 10^-5 T. To determine the force between the conductors, one must find the magnetic field from one wire and then apply the formula F = ILB to calculate the force on the second wire, without adding or subtracting forces based on their directions. The right-hand rule (RHR) is used to establish the direction of the magnetic field and the forces involved.
  • Understanding of Ampère's Law and magnetic fields
  • Familiarity with the right-hand rule (RHR) for determining direction
  • Knowledge of the formula for magnetic force on a conductor (F = ILB)
  • Basic principles of electromagnetism
  • Study the derivation of Ampère's Law and its applications
  • Learn about the interactions between multiple current-carrying conductors
  • Explore the implications of the right-hand rule in various electromagnetic scenarios
  • Investigate the effects of varying current magnitudes and distances on the force between conductors
Students and educators in physics, electrical engineers, and anyone interested in understanding the principles of electromagnetism and the behavior of current-carrying conductors.
vrobins1
Consider two straight conductors of length 1 m, each of them carrying a current of I = 2 A. If they are placed 1 m apart, what is the magnitude and direction of the force between these two conductors if there currents are
a) in the same direction;
b) in the opposite direction.
I know that
B = [tex]\mu[/tex]0*I/2[tex]\pi[/tex]r
I also know that that force on a conductor in general is F = ILBsin[tex]\theta[/tex].
I calculated the magnitude of B according to the equation above and got 3.95-5 T.
I'm not sure how to find the force of TWO conductors together though.
Would you just do F = ILB for both conductors, adding the two F values of they are going in the same direction and subtracting if they are going in opposite directions?
Is the direction determined by the RHR?
Any insight would be much appreciated. Thanks!
Not exactly. To find the force on wire #2, start by finding the field from wire #1, then find the force it exerts on wire #2. That's it: the force that wire #1 exerts on wire #2. Of course, wire #2 exerts the same force on wire #1. (Don't add/subtract the F values.)
Yes. The direction of the field created is determined by the RHR, and so is the direction of the force that each wire exerts on the other.
  • · Replies 40 ·
  • · Replies 43 ·
  • · Replies 23 ·
