Double Slit Interference (nonzero slit width)
The problem involves a double slit interference setup where two slits of width 0.1 mm are illuminated by light of wavelength 589 nm. The slits are separated by 3.0 mm, and the distance to the screen is 5.0 m. The original poster attempts to calculate the distance between adjacent bright fringes on the screen while considering the effects of slit width on the interference pattern.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss treating the problem as a superposition of two diffraction patterns from each slit. The original poster expresses difficulty in deriving the necessary equations and seeks guidance on the correct approach. Questions arise regarding the relationships between the variables involved, particularly concerning the conditions for bright fringes and the implications of the electric field equations presented.
Participants are actively engaging with the problem, questioning the original poster's assumptions and clarifying the relationships between the variables. Some guidance has been offered regarding the significance of the terms in the equations, particularly in the context of fringe spacing near the central axis. However, there is no explicit consensus on the approach to take.
There is a noted confusion regarding the correct use of variables φ and β in the equations presented. The original poster's understanding of the implications of slit width on the interference pattern is also under discussion.
TOD
A mask with 2 slits is illuminated by a light of 589nm wavelength. Slits each have a 0.1mm width separated (centre to centre) by 3.0mm. Calculate the distance between adjacent bright fringes on the screen if a screen is placed 5.0m away from the slits.
Where
[tex]\beta[/tex]=2[tex]\pi[/tex]dsin[tex]\theta[/tex]/[tex]\lambda[/tex]
[tex]\phi[/tex]=2[tex]\pi[/tex]asin[tex]\theta[/tex]/[tex]\lambda[/tex]
d=slit separation
a=slit width
E=E(max)cos[tex]\frac{\phi}{2}[/tex]*([tex]\frac{sin(\beta/2)}{\beta/2}[/tex])
(sorry, no good with this latex stuff, some stuff not showing right)
First, I assume that if given a slit width of some size then we cannot assume that the interference comes from points sources. So to calculate the distance between adjacent bright fringes, I took on the formula for intensity and turned it into electric field of some form (just square rooted) and tried to differentiate the electric field and then find the roots of the equation. However I have found this extremely lengthy and most probably unnecessary. Can anyone get me started in the correct direction?
Treat the problem as the superposition of two diffraction patterns, one from each 0.1 mm slit. Where a bright fringe from one source occupies the same position as the other source's bright fringe this is a bright fringe of the double slit system.
TOD said:
Where
Looks like you have φ and β switched around here, given your expression for E below.
d=slit separation
a=slit width
Okay. And what must
cos(φ/2) = cos[π d sin(θ) / λ ]
be equal to, for a bright intensity fringe to occur?
Ah yes, my bad.
Okay. And what must
Plus or minus one? So I could in theory get that thing to equal 1, but that doesn't mean the product of this and the sine of a sine function is maximum does it?
Redbelly98 said:
Okay. And what must
TOD said:
Plus or minus one?
Yes, exactly.
That's a good question. The answer, in practice, is yes it does. Since measurements of fringe spacing are typically done near the central axis, where
sin(β/2) / (β/2) ≈ 1,​
the effect of the sin(β/2) term can be ignored.
Or put another way, the cos(φ/2) term oscillates many many times for each oscillation of the sin(β/2) term. This is because d and φ are much larger than a and β, respectively. (In the present case they are 30 times larger.)
Hope that helps.
Redbelly98 said:
Yes, exactly.
Hope that helps.
Very interesting. Thanks for the help.
  • · Replies 28 ·
