Understanding 1D Walks and Their Properties
  • Thread starter Thread starter superwolf
    1d Properties
The discussion centers around the properties of one-dimensional random walks, specifically the relationship between the mean squared displacement and the distribution of particle positions after a series of steps. Participants are examining the mathematical implications of the step size and the statistical properties of the resulting distribution.
  • Participants are discussing the transition from the mean squared displacement to the confidence limits associated with a normal distribution. There is an exploration of the central limit theorem and its application to modeling the steps of the walk as a binomial distribution.
Some participants have offered insights into the statistical properties of the distribution, including the relationship between variance and standard deviation. There is ongoing exploration of how to derive the standard deviation from the definition of variance, with no explicit consensus reached yet.
Participants are working under the assumption that the total length of the walk is normally distributed, and there is a focus on the implications of this assumption for the analysis of the random walk.
superwolf
My textbook simply states that
"For a simple 1D walk with step size L:
<x^2> = NL^2
So after N steps 99.7% of the particles will be closer then 3L sqrt(N) from the centre"
How does it get from the first to the latter?
Hi Superwolf
[tex]3\sigma[/tex] (3 standard deviations) is 99.7% confidence limit for a normal distribution
So the 99.7 and <x^2> seem to point to using variance of a normal distribution
Which shouldn't be too had to get too asuming we know the total length is normally distributed...
Taken from wiki:
In probability theory, the central limit theorem (CLT) states conditions under which the sum of a sufficiently large number of independent random variables
http://en.wikipedia.org/wiki/Central_limit_theorem
So each step can be modeled as a binomial distribution with outcomes (L,-L) and 0.5 chance of success, and the sum giving the average length is then approximated by a normal distributions at large N
So L sqrt(N) is the standard deviation?
i would strat with the definition of variance and work from there
[tex]\sigma^2 = <(x - \bar{x})^2>[/tex]
where the <> is expectation
it should be a simple matter to get the standard deviation from there, and will probably end up as L sqrt(N), if you convince youself the mean is zero
