Solving Integration Problems for EIy and ymax
  • Thread starter Thread starter Aerstz
    Integration
The discussion focuses on solving integration problems related to beam deflection using the equations EIdy/dx = - (Fx^2)/4 + (FL^2)/16 and y = (Fx/48EI)(3L^2 - 4x^2). The constant A is derived from boundary conditions, specifically A = (FL^2)/16 when the slope dy/dx equals 0 at x = 1/2L. The second constant B is determined to be zero after integration, leading to the final expression for ymax = (FL^3)/48EI. The user seeks clarification on the derivation of these constants and the relationship between the equations.
  • Understanding of beam theory and deflection principles
  • Familiarity with integration techniques in calculus
  • Knowledge of boundary conditions in differential equations
  • Proficiency in applying the Euler-Bernoulli beam equation
  • Study the derivation of boundary conditions in beam deflection problems
  • Learn about the Euler-Bernoulli beam theory and its applications
  • Explore integration techniques for solving differential equations
  • Investigate the relationship between deflection equations and physical interpretations in structural engineering
Students and professionals in structural engineering, mechanical engineering, and applied mathematics who are working on beam deflection problems and require a deeper understanding of integration in this context.
Aerstz
Two questions are of the same problem (these are taken from a textbook):
EIdy/dx = - (Fx^2)/4 + A
The constant A can be obtained from the boundary conditions: slope dy/dx = 0, x = 1/2L. Thus A = (FL^2)/16 hence
My problem 1: I have absolutely no idea why A = (FL^2)/16. If someone could please show me in a few small steps how A was determined, I should be very grateful!
Integrating again (with respect to x), the second constant, B, equals zero thus
EIy = - (Fx^2)/4 + (FL^2)/16 + B
B = 0
y = (Fx/48EI) (3L^2 - 4x^2)
x = 1/2 L thus
ymax = (FL^3)/48EI
My problem 2: I have no idea how the solution for ymax was determined. I Also have no idea why y = (Fx/48EI) (3L^2 - 4x^2) when EIy = - (Fx^2)/4 + (FL^2)/16 + B. Is the equation for y simply the equation for EIy transposed for y? Because when I tried them I ended up with values which did not fit. (Did I make a simple error in my calculating, or is something else going on?)
Please could you explain to me what is going on in the above equations?
This is a scan of the book from whence the equations originated:
http://img16.imageshack.us/img16/9725/beamproblembookscan.png
  • · Replies 18 ·
  • · Replies 18 ·
