Newton's Law of Cooling. little question about 'Specific heat' of Mercury
Newton's Law of Cooling describes the time required to cool or heat an object based on the formula t = mCp(Ts - Tf)/Q. In this discussion, the user seeks to determine the specific heat capacity (Cp) of mercury for a given scenario where Q is 1700 W, m is 500 kg, Ts is 1°C, and Tf is 67°C. The specific heat of mercury is established as 0.139 joules per gram per degree Celsius, which translates to 139 J/kg°C when converted for mass in kilograms.
  • Understanding of Newton's Law of Cooling
  • Knowledge of specific heat capacity
  • Basic principles of thermodynamics
  • Ability to perform unit conversions (grams to kilograms)
  • Research the implications of specific heat in thermal management
  • Explore advanced applications of Newton's Law of Cooling in engineering
  • Learn about the thermal properties of different materials
  • Study heat transfer methods and their calculations
Students, engineers, and scientists interested in thermodynamics, particularly those working with heat transfer and material properties.
matthewgill
Time Required to Cool (or heat) an Object [Also known as Newton's Law of Cooling]
t=mCp(Ts-Tf)/Q
Where;
Q is the heat added (or being removed) from the object in watts
m is the mass (weight) of the object in Kg
Cp is the Specific heat of the object material in J/Kg C
t is the time required to cool down (or heat up) the object in seconds
Ts is the starting temperature in C
Tf is the final temperature in C
Here is what i am entering:
Q - 1700 W
m - 500 KG
Cp - ?
Ts - 1 degC
Tf - 67 degC
But what should i enter for the 'Specific heat of the object material in J/Kg C'?
The Object is Mercury.
Thank you
Science news on Phys.org
Cp=0.139 joules per gram per degree C.
  • · Replies 24 ·
  • · Replies 27 ·
  • · Replies 26 ·
17K
