What is the time dependence of the Omegas?
  • Context: Graduate
  • Thread starter Thread starter Amanheis
    Time Time dependence
The discussion revolves around the time dependence of the density parameters Omega_M and Omega_Lambda in a flat universe, with references to a figure from Sean Carroll's website. Participants explore how these parameters evolve over time and the implications of their relationships.
  • One participant expresses confusion about how Omega_M and Omega_Lambda evolve with time, assuming a flat universe where Omega_M + Omega_Lambda = 1.
  • Another participant suggests that time dependency may not be the correct approach if time is considered an emergent property of the universe.
  • There is a challenge regarding the validity of a specific formula related to the evolution of Omega_Lambda, with a request for clarification on which formula is being referenced.
  • Concerns are raised about the reasoning behind the calculation of critical density and its dependence on the universe's contents.
  • One participant corrects another's assumption that H is proportional to the scale factor a, arguing that H is much larger in the past while a is smaller.
  • Another participant emphasizes that Omega_M + Omega_Lambda does not equal 1 at all times, noting the need to consider Omega_R (radiation) and Omega_K (curvature) in the total density parameter sum.
  • A participant proposes a new assumption that rho_c = rho_M0/a^3 + rho_Lambda, suggesting this maintains the relationship between Omega_M and Omega_Lambda while yielding a graph consistent with Carroll's figure.
  • One participant acknowledges the neglect of radiation in their initial assumptions, while another points out that radiation was significant in the early universe.
Participants exhibit disagreement regarding the assumptions about the evolution of Omega_M and Omega_Lambda, the role of radiation, and the validity of certain calculations. No consensus is reached on the correct approach or assumptions.
Participants express uncertainty about the implications of their assumptions, particularly regarding the constancy of curvature (k) and the role of radiation in the universe's evolution. There are unresolved questions about the relationship between H and a, as well as the definition of critical density.
Amanheis
I am really puzzled. I have several questions about how Omega_M and Omega_Lambda evolve with time. Ultimately I want to reconstruct figure 1 one Sean Carroll's Website http://nedwww.ipac.caltech.edu/level5/March01/Carroll/Carroll1.html.
First of all, I will assume a flat universe throughout this post. As I understand, this means the universe was and will be always flat, although I couldn't proof this. If someone has a quick proof for that, I'd appreciate it.
That also means, that for all times, Omega_M + Omega_Lambda = 1. (By Omega_M0 etc. I mean the density parameter or whatever now, anything else means it is dependent on a.)
Now my problems:
1. Omega_M = rho_M/rho_c
2. rho_M = rho_M0/a^3
3. rho_c ~ a^2 because of H^2 in the denominator of rho_c (fixed a sign there...)
4. Hence Omega_M = Omega_M0/a^5
5. Therefore Omega_Lamda = 1 - Omega_M0/a^5 ??
But since rho_Lambda = const, how is Omega_Lambda defined such that eq. 5 holds for all times? It can't be a simple a^n dependence, especially not rho_Lambda/rho_c (except for n=5, but why would that be).
Also, if Omega_M = const/a^5, what happens if a is small enough early in the universe such that Omega_M > 1? I feel really stupid.
Space news on Phys.org
I don't think time dependency is the right approach if you allow for the possibility time is an emergent propoerty of the universe. The formula you cite does not resolve this issue.
I am sorry, I don't understand. What formula do you mean? Which one of them is wrong? And what do you think is the right approach? I mean, call it a-dependence instead of time-dependence, but the question remains: How got Carroll to his little figure of the a-dependence of d/da Omega_Lambda?
Now my problems:
I don't see the reason for your step 3.
Step 3. seems wrong. You seem to be acting as if you thought that H is proportional to a.
But H is much larger in the past
while the scalefactor a is smaller in the past.
So there can be no simple proportionality between H and a.
Yes, step 3 is wrong. It's not quite that easy. You have to take into account the full contents of the universe to compute rho_c in terms of said contents.
Well my reasoning was that H is defined as "a dot over a". And I somehow assumed that "a dot" is independent of "a", just like a general coordinate "q dot" is independent of "q" in classical mechanics.
But thanks, I'll take a closer look on the critical density.
Second thing you should note is that Omega_M + Omega_L isn't = 1 at all times. You have to consider Omega_R (radiation) and Omega_K (curvature). The sum of all these values is = 1.
Well I obviously neglected radiation (as it is very common) and stated at the beginning that I am assuming a flat universe.
Also, I am now assuming that rho_c = rho_M0/a^3 + rho_Lambda.
With this, rho_M/rho_c + rho_Lambda/rho_c is always 1 and neither Omega_M nor Omega_Lambda leave the intervall [0,1]. This also yields the same graph as the one by Sean Carroll, which is why I think I am on the right track.
Note that this presumes that k=0 at any given moment. I am still not exactly sure why k is constant for k=0 and not constant if k>/<0.
Ah I apologize I didn't see the assumption of a flat universe. I know radiation isn't a big deal right now, and is almost negligible but at different times of the Universe's lifespan, radiation had been a factor, and sometimes even dominant (when you delve into the past). So that's why I thought I'd put that out there. I'm sure they're assuming that radiation has always been 0 or negligible.
  • · Replies 51 ·
  • · Replies 51 ·
  • · Replies 20 ·
  • · Replies 32 ·
