Thread Closed
Max distance of resolution from 2 point sources of light
Share Thread Thread Tools
Apr26-09, 11:38 AM   #1
Two point sources of light are separated by 4.91 cm. As viewed through a 12.1 μm diameter pinhole, what is the maximum distance from which they can be resolved if red light (λ = 690 nm) is used?
2. Relevant equations
sinθ = 1.22*(λ/D)
y= L*tan θ
3. The attempt at a solution
Using sinθ = 1.22*(λ/D) , I solve for θ. Then using θ I put it into the second equation,
y= L*tan θ.
I should then be able to solve for L, but the problem is i don't know what y is, or what value i can use for y. Any suggestions? Thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr26-09, 07:58 PM   #2
Mentor
Have you drawn a diagram? Looks like L is the distance between the pinhole and the two sources, and θ is the angle between the two sources as viewed from the pinhole. What would that make y?
p.s., the small angle approximations θ ≈ sinθ ≈ tanθ may be used here.
Thread Closed
Thread Tools
Similar Threads for: Max distance of resolution from 2 point sources of light
Thread Forum Replies
Please help to Find coordinates of a point formula Angle,Distance & first point known Differential Geometry 3
[SOLVED] Minimum Distance Between Two Sound Sources Introductory Physics Homework 2
Calculating point X on the Golden Spiral knowing a point and a distance Calculus 0
Light point sources General Physics 1
