Thread Closed
What is final temperature?
Share Thread Thread Tools
Apr29-09, 10:20 PM   #1
A 81-g ice cube at 0°C is placed in 878 g of water at 25°C. What is the final temperature of the mixture?
2. Relevant equations
No heat is loss therefore m*Cp*deltaT+m*Cp*deltaT=0
Cp ice=2.09
Cp water=4.19
3. The attempt at a solution
878*4.19*(Tf-25)+81*2.09*(Tf-0)=0
3678.82Tf+169.29Tf=91970.5
Tf=23.9C
The answer is wrong...don't know why...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Apr29-09, 10:26 PM   #2
Recognitions:
Homework Helper Homework Help
What about the latent heat of fusion for ice?
Apr29-09, 10:27 PM   #3
So you think you'll have ice at 23 degrees?
The ice will melt (at least partially). This will take energy (heat) from the water so teh final temperature will be lower.
You have to take into account the melting heat Q=m_ice*l_melting
where m_ice is the mass of ice that melts (may be equal to the initial mass) and l_melting is the latent heat (heat of fusion) for ice.
In order to see if the ice melts completely (or not) you can compare the heat necessary to melt all th e ice with the heat released by the water when it cools to zero degrees.
Apr29-09, 10:54 PM   #4
Qmelt=81g*333j/g
=26973
So...
878*4.19*(Tf-25)+81*2.09*(Tf-0)+26973=0
3848.11Tf=64997.5
Tf=16.89
Which is still wrong...what am I doing wrong now?
Apr29-09, 11:03 PM   #5
You don't have ice heating up. It's already at 0 degrees. There is no term like 81*2.09*(Tf-25)
It's the water from melting that will heat up.
Apr29-09, 11:15 PM   #6
So then it should be...
878*4.19*(Tf-25)+26973=0
Tf=17.668
That's not correct either...
Apr29-09, 11:37 PM   #7
Recognitions:
After melting completely, the ice water takes heat from water to reach the final temperature.
Apr29-09, 11:45 PM   #8
Ok...if that is so...then...
81g*4.190j/kg*Tf + 878g*4.19j/kg*Tf -91970.5 + 81*333 = 0
so Tf = 16.1757
Apr29-09, 11:56 PM   #9
Recognitions:
Appears to be correct.
Thread Closed
Thread Tools
Similar Threads for: What is final temperature?
Thread Forum Replies
Calculating Final Temperature Biology, Chemistry & Other Homework 5
Calorimetry- how do I know the final temperature? Biology, Chemistry & Other Homework 2
Final temperature of system Introductory Physics Homework 2
Finding final temperature Introductory Physics Homework 1
Final temperature Introductory Physics Homework 0
