How Do Magnetic Fields Interact at Point P Between Parallel Wires?
The discussion focuses on calculating the magnetic field components at point P between two parallel wires carrying 25-A currents. The magnetic field magnitude due to the lower wire is calculated using the formula \(\mu_0 I / (2 \pi r)\), resulting in 3.759E-5 T. The angle θ is determined using the Law of Cosines, yielding 19.814 degrees, which is then used to find the y-component of the magnetic field as 1.274E-5 T. The user encounters difficulty calculating the x-component, suspecting issues with significant figures, rounding errors, or sign conventions.
  • Understanding of magnetic fields and their calculations
  • Familiarity with the Law of Cosines
  • Knowledge of trigonometric functions (sine and cosine)
  • Basic principles of electromagnetism
  • Study the application of the Biot-Savart Law in magnetic field calculations
  • Learn about vector components in magnetic field analysis
  • Review significant figures and error analysis in physics calculations
  • Explore the effects of current direction on magnetic field orientation
Students studying electromagnetism, physics educators, and anyone involved in solving problems related to magnetic fields and currents in parallel wires.
GDGirl
Two long thin parallel wires a distance d = 15.3 cm apart carry 25-A currents (I) in the same direction. The magnetic field is measured at point P, a distance d1 = 13.3 cm from the lower wire and a distance d2 = 5.3 cm from the upper wire.
a. Find the x and y components of the magnetic field at P due to the current in the lower wire only.
HELP: First find the magnitude of the field due to the current in the lower wire.
HELP: To find the direction of the field, the Law of Cosines will be helpful: for a triangle of sides a, b, and c, the angle θ between sides a and b is given by c2 = a2 + b2 - 2 a b cosθ.
https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/Knox/phys130a/spring/homework/13/04/HW14_4.jpg
Magnitude=[tex]\mu[/tex]0I/2[tex]\pi[/tex]r
So I found the magnitude to be [tex]\mu[/tex]0(25)/2[tex]\pi[/tex](.133)=3.759E-5
then I use the Law of Cosines to find that theta=19.814
so then 90-19.814=70.186
Cos of that= y/3.759e-5
which gives me y=1.274e-5
Which is correct.
However, when I use Sin of 70.186=x/3.759e-5 I get 3.536e-5, but this is not correct. I'm not sure what I'm doing wrong here. :/ I've never quite understand how to tell when you use Sin and Cos for which value anyway.
Your work looks pretty good, so I imagine the problem is one of the following:
Wrong number of significant figures in final answer,
Final answer slightly wrong from roundoff error,
or
+/- Sign error in final answer.
In your diagram, have you drawn the direction of B due to the lower wire? That might help clear up whether it's + or -.
I didn't even think about the fact that it could be negative. B is going anti-clockwise, so it's negative. Thanks!
