| Thread Closed |
Surface charge density on the outer surface of a plate in a parallel plate capacitor |
Share Thread | Thread Tools |
| May27-09, 01:41 PM | #1 |
Let me know if the following reasoning is correct :
If the surface charge density on the internal surface of one of the plates in a parallel plate capacitor is Sigma, which becomes Sigma/K, when a dielectric material is inserted between the plates with dielectric constant K, so the charge density on the outer surface of the same plate will be Sigma - Sigma/K |
| May27-09, 04:04 PM | #2 |
If you have a parallel plate capacitor with charge +/-Q on the inside of each plate, the voltage between the two plates is (d=separation, A = area)
V=Q/C = Qd/e0A If you now stick a dielectric with relative dielectric constant k into the gap, the voltage becomes V=Q/C = Qd/k e0A The unchanged charge remains on the inside of both plates. The stored energy is now W = (1/2) Q V = Q2d/k e0A So the stored energy is reduced when you inserted the dielectric. Where did it go? If there is any unbalanced charge on the outer surface of either plate, it will remain there. Gauss law will tell you that the E field lines from charges on the outside of the plates are still there, and terminate at infinity. |
| May27-09, 11:33 PM | #3 |
Hi Bob S,
Let me rephrase my question : When a dielectric is inserted, some charge is induced on the inside of the plate, so the opposite charge of equal amount will be induced on the outside of the plate. Is it correct? Actually, I am making a question, to be handed out to students, based on the above assumption, so I wanted to cross check if the above reasoning is correct indeed. |
| May27-09, 11:48 PM | #4 |
Charge-up a plate capacitor. Let things settle until there is no current. The electric potential on both sides of a plate will be equal to each other.
All the charge is on the surface of the conductor, so we talk about the surface charge density. Although the electric potential is equal throughout the volume of the plate, the charge density is not. The charge will be redistributed upon the surface to equalize the electric potential. |
| May28-09, 12:58 AM | #5 |
Hi Phrak,
So, is the reasoning in my original post is correct? |
| May30-09, 12:35 AM | #6 |
What should draw electrons to the outward facing surface? You need to specify the environment or no answer can be given. I presume you mean that there are no external charges present, in which case the charge density on the external side is zero. |
| May30-09, 01:53 AM | #7 |
Hi Phrak,
What I have proposed is this : Initially there is no charge on the outer surface of the plate, and the surface charge density on the inner surface is Sigma. When the dielectric is inserted, the charge density on the inner surface is = Sigma / K, where K is the dielectric constant of the material. So, rest of the charge moves on the outer surface. Hence the surface charge density on the outer surface becomes : Sigma - Sigma/K |
| May30-09, 05:50 AM | #8 |
No, the charge density is just sigma/k. The rest of the charges will migrate back between the connected leads to the opposite plate. In essence, the stored energy does not change as the loss in power stored in the electric field between the plates due to the lessening of the charges is made up by energy stored in the polarization of the dielectric. This assumes that you still have a DC potential hooked up between the plates.
If you have the parallel plate capacitor charged, at steady state, then disconnect the leads, and then move a dielectric in between the two plates, the charge on the plates is still sigma, the charge has nowhere to go (barring dielectric breakdown, etc). The difference here is that moving the dielectric between the plates will require extra work, this extra work is stored in the polarization of the dielectric. So since you have to add energy into the system, there is no violation of energy conservation. |
| May30-09, 10:28 AM | #9 |
Mentor
That said, I don't think there is enough information. Are the two capacitor plates charged with some voltage source that remains connected? Are they charged and then disconnected? Etc. |
| May30-09, 12:04 PM | #10 |
If there is a charge +/-sigma on the inside of both plates, and the plates are NOT connected to a power supply, when a dielectric with constant k is inserted into the gap, the charge sigma will remain the same, and the voltage between the plates will drop by a factor k.
If there is a charge +/-sigma on the inside of both plates, and the plates ARE connected to a power supply, when a dielectric with constant k is inserted into the gap, the charge sigma will drop by a factor k, and the voltage between the plates will be unchanged. If there is no charge on the OUTSIDE of the capacitor at the beginning, meaning Gauss' Law surface integral outside the capacitor =0, there are no field lines to (and charges at) infinity, there will be no outside charges after the dielectric is inserted. In either case, the total energy stored in the capacitor is reduced because the stored energy W is W = (1/2) Q V = (1/2) C V2 = (1/2)Q2/C = (1/2)Q2d/k e0A. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Surface charge density on the outer surface of a plate in a parallel plate capacitor
| Parallel plate or non parallel plate capacitor!!!!!! | General Physics | 0 | ||
| parallel plate capacitor (voltage and charge relative to distance) | General Physics | 2 | ||
| Charge on Parallel Plate Capacitor | Introductory Physics Homework | 4 | ||
| A proton is released from rest at the positive plate of a parallel-plate capacitor. | Introductory Physics Homework | 16 | ||
| Determine the charge density on either plate (capacitor) | Introductory Physics Homework | 4 | ||
