rtareen
- 162
- 32
Lets go through the example problem until we get to the part I don't understand. Figure 25-17 can be used as a reference to all questions. From part (a) to part (b) we eventually find the charge q on one plate (and by default the charge -q on the other). No problem there. The battery is then removed so we know the plate charges will remain constant throughout the problem.
Part (c) is where i start getting confused. We use Gauss' law to find the field between the plate and the dielectric and the result is the same as if the dielectric was not there. Doesn't the induced charge on the dielectric contribute the field in between? We know the result is true due to Gauss; law saying so but is there any explanation? My guess is that we are treating faces where the induced charges are as infinite planes and since the field of infinite planes don't depend on distance they cancel out outside the of dielectric? Is that right? Please explain. It doesn't make sense to treat such a small dielectric as an infinite plane.
In part (d) we use Eq. 25-36 but that equation was derived for a dielectric that that fills the space in between and is in contact with the plates. Why is it the same? Also, we can only use Gauss' Law to find the field that is constant at all points on the Gaussian surface. Is the field the same at both ends of Gaussian Surface II? It is clearly not in the area in between. Intuitively it is not either because the field in the upper part of Gaussian Surface II should be weaker due to there being less positive charge to attract the induced negative charge.
I might be missing something fundamental that is not allowing me to fully understand what is going on here.
