Thread Closed
Write a Function in Ti 89 titanium
Share Thread Thread Tools
May30-09, 09:10 PM   #1
Recognitions:
Gold Membership Gold Member
Hello,
I wish to write a function that takes in 3 arguments and outputs 1. I want it to be a saved function so that I can call it at will like cos() or ln()
How do i go about doing this? I am unsure of the syntax.
Let's say it is really simple like:
f(x,y,z)=x+y+z
So from the home screen I would like to type f(1,2,3) and have it return 6
Any thoughts?
EDIT: okay so maybe that is easier than I thought. The problem I am running into is that you cannot use the "store" key when writing a function.
For example if I wanted to write the above like this:
f(x,y,z)
Func
(x+y)->A
Return A+z
EndFunc
I cannot. I have to write:
f(x,y,z)
Func
Return x+y+z
EndFunc
Also, is there a "shift key" that will make my variables Capital if I need E instead of e ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May30-09, 09:43 PM   #2
Recognitions:
From a Google search for ti-89 function:
http://www.batesville.k12.in.us/phys..._functions.htm
You can probably do this as long as the function is not overly complicated
May30-09, 09:48 PM   #3
Recognitions:
Quote by MATLABdude View Post
Yeah. That is a "user-defined" as in, you need to redefine it every time you need it.
I edited my OP. What I posted shows how to do it from program editor-->functions
Unfortunately, if it is a complicated expression, it is a bi##h to write as you cannot break it down into simpler components using the store button.
Thread Closed
Thread Tools
Similar Threads for: Write a Function in Ti 89 titanium
Thread Forum Replies
How to manually write the code for a matlab delta function... Engineering, Comp Sci, & Technology Homework 10
MIPS -- write a function to remove blanks Programming & Comp Sci 1
Titanium and Titanium Alloys Materials & Chemical Engineering 0
TI-89 Titanium Calculators 2
How do you write equations in a single sine function? Calculus & Beyond Homework 1
