Calculating Charge Transfer between Objects
  • Thread starter Thread starter alithefickle
    Electrons
The problem involves calculating the charge transfer between two objects: a plate with a charge of -3.0 µC and a rod with a charge of +2.0 µC. The objective is to determine how many electrons must be transferred from the plate to the rod for both objects to have the same charge.
  • Exploratory, Assumption checking
  • The original poster seeks clarification on the solution process that leads to the final answer provided by the teacher. Some participants question the effects of touching the objects together and the resulting final charges. Others express uncertainty about their calculations of the final charges on both objects.
The discussion is ongoing, with participants exploring the implications of charge transfer and questioning the correctness of their calculations. Guidance has been offered to consider the final charges after contact, but no consensus has been reached on the specific calculations.
The original poster notes that the teacher provided a final answer but did not explain the solution process. There is an emphasis on not providing complete solutions, aligning with the forum's guidelines.
alithefickle
Hi everyone, would you kindly help me with our homework..Although our teacher was able to give the final answer but he couldn't find a solution that will result to the answer.tsk tsk tsk. Here is the problem.
A Plate carries a charge of -3.0 uC, while a rod carries a charge of +2.0 uC. How many electrons must be transferred from the plate to the rod, so that both object have the same charge?
The final answer given by the teacher is:
1.6 x 10 exp 13 electrons
Would you kindly give me the solution on how the book came up with this answer? Many thanks..cheers!
q = Ne
N = q/e
Welcome to PhysicsForums!
We don't do your homework for you here, but we'll work with you. First off, when they're touched together, what happens? What is the final charge on each object? How many electrons is this?
electrons are transferred to the other material.. Final charge for plate = 4.8 x10 exp-25
for rod is -3.2 x 10exp-25...Im not sure if this is correct...would you kindly check.tnx
up for now
  • · Replies 16 ·
