Why is (0,1) not compact in topology?
  • Context: Graduate
  • Thread starter Thread starter Newtime
    Compact
The discussion revolves around the concept of compactness in topology, specifically addressing why the open interval (0,1) is not compact while the closed interval [0,1] is. Participants explore definitions, examples, and counterexamples related to open covers and finite subcovers.
  • Some participants express confusion about the definition of compactness, noting that every open cover must have a finite subcover.
  • One participant suggests an open cover of the form {(-2,2),(-1,3),(0,4)} and questions the existence of a finite subcover.
  • Another participant introduces the family of open sets (1/n,1) and discusses its implications for covering (0,1), emphasizing that it does cover (0,1) but lacks a finite subcover.
  • Several participants clarify that any finite subset of the intervals (1/n, 1) must have a largest n, which leads to gaps in coverage for (0,1).
  • There is a discussion about the Heine-Borel theorem and its implications for compactness in different topological spaces, with some participants questioning its directionality.
  • One participant raises a point about the nature of open sets and whether certain unions can be considered finite subcovers, leading to further clarification on the definition of open sets in topology.
  • Another participant provides an example of a set that is closed and bounded but not compact in the context of rational numbers, illustrating the nuances of compactness in different topological spaces.
Participants generally agree on the definition of compactness and the specific case of (0,1) not being compact due to the lack of a finite subcover from certain open covers. However, there are competing views on the implications of the Heine-Borel theorem and the nature of open sets, indicating that some aspects of the discussion remain unresolved.
Some participants express uncertainty about the definitions and implications of compactness, open covers, and finite subcovers, highlighting the complexity of the topic. There are also references to specific examples and counterexamples that illustrate the nuances of compactness in various topological contexts.
This discussion may be useful for students and individuals interested in topology, particularly those grappling with the concepts of compactness, open covers, and the implications of the Heine-Borel theorem.
Newtime
I've only just started getting into Topology and a few examples of compactedness have me a little confused. For instace, the one in the title: how is the open interval (0,1) not compact but [0,1] is? Obivously I'm making some sort of logical mistake but the way I think about it is that there are any number of open covers for (0,1). I'll use {(-2,2),(-1,3),(0,4)}. By definition, there needs to exist a finite subcover which still contains (0,1) right? So couldn't that finite subcover simply be {(-1,3)}? I have a feeling the reason I'm not grasping this example is because the definition states that a finite subcover must exist for all open covers of a given set, but I still can't think of an open cover which does not have a finite subcover which contains (0,1). Thanks.
consider the family of open sets of the form (1,1/n) where n = 1,2,...
note the definition of compact is that EVERY open cover contains a finite subcover.
edit: oops that should be (1/n,1) of course!
I'm not the greatest when it comes to series and sequences, but if the right term, 1/n, converges to 0 can we regard it as simply 0? If so then wouldn't the cover and finite subcover of (1/n,1) be the set itself? If we can't regard it as zero then it seems that clearly there is not a finite subcover since there will always be some n such that 1/n is greater than 0 but then again that implies that the set does not cover (0,1) to begin with. Thank you for the quick reply though, this has been bugging me for a while.
The set of all intervals (1/n,1) DOES cover the interval (0,1). If x is in (0,1) then necessarily there exists N such that 1/N < x and hence x is in (1/N,1). So taking the union of all the intervals (1/n,1) for each n gives us the interval (0,1) as required. And trivially there is no finite subcover, since if there was there would be a list [itex](1/n_1, 1), (1/n_2, 1),...[/itex] and we can pick the largest nk and the union of these intervals would just be the interval (1/nk,1)
Very helpful, thanks. Just to make absolutely sure I've got this though: the reason there cannot exist a finite subcover is because the finite subcover would end up being the cover itself which is not finite.
More succinctly, any finite subset of {An} with An= (1/n, 1), must have a largest n. Call that largest n, "N", so the the subset contains no member of (0, 1) less than 1/N and so can't be a cover for (0, 1).
Well put, thanks.
A lot of people confuse "for all" with "there exists." A way to keep it straight is that there is always an open cover consisting of precisely one set.
We all know that [0,1] is compact but if we look at the set {{0},{A_n},{1}} where A_n = (1/n,1) where n is an integer value which covers [0,1], but there is no finite subset of this set which cover [0,1]. I understand there is a flaw in my argument I just want to know what it is.
{0} and {1} are not open sets so you only provided a cover with no finite subcover, but compactness only guarantees that an OPEN cover has a finite subcover. Otherwise no infinite set could be compact because we could just cover it by all it's one-element subsets.
Wow why didn't I think of that. This stuff escapes me some times. Thanks for the quick response and the detailed answer.
If you want to use machinery, in Reals (or any complete space) a set is compact iff it is closed and bounded and you can look at proof of the theorem to get an insight on how so.
But of course at the initial stages of your learning it is best to try to do this via constructing counter examples etc.
Could you please post a link showing me the proof?
dasdos
The proof is the Heine-Borel theorem.
Doesn't Heine-Borel only prove in one direction? I was taught that if its closed and bounded then its compact. How do we know that every compact set has to be closed and bounded (in a Hausdorff space).
hi,
the subject seems rather cold. but there are things i still can't comprehend after reading your discussions several times.
for example why can't we take (0 , 1/n(k) ) U ( 1/n(k+1), 1) for simplicitys sake. this is a finite subcover is it not ? (k are indexes)
ps: i am not a mathematician so be generous with the explanations..
mbarby said:
hi,
A finite subcover of what??
If you take [itex](]1/n,1[)_n[/itex], then this forms an open cover of ]0,1[ but not a finite subcover. You can't take ]0/1n[ as an element of a finite subcover, because it was not an element of the original cover all along, i.e. ]0,1/n[ is not of the form ]1/n,1[.
let me rephrased this so that i understand it right: when we say open we mean open in the topological sense, i.e. if (0,1] is given as open then all the open subsets should be in the form of (x,y], is that right ?
For example, in the set of rational numbers with the topology inherited from the real numbers (the metric topology with d(p,q)= |p- q|) all compact sets are closed and bounded but there exist sets that are both closed and bounded that are NOT compact.]
For example, the set [itex]\{x\in Q| x^2\le 2\}[/itex] is both closed and bounded, in that topology, but not compact.
No, not all open subsets are of the form (x,y] there. The (x,y] certainly are open and form a "subbasis for the topology", but there are more open sets than just the (x,y].
For example, [itex](0,1/2)\cup (1/2,1][/itex] is also open in (0,1].
Also [itex][0,1]\cap \mathbb{Q}[/itex] is closed and bounded, but not compact in [itex]\mathbb{Q}[/itex]. There are very few compact sets in Q (in technical terms: the rationals are not locally compact).
but the result of the unions itself is of the form (x,y] . so this is considered open i guess...
Not really, the result of the union is simply (0,1] with the point 1/2 removed. So it's not from the form (x,y]. It is open however...
thx for the help, i will have to go through all this once more , i think :). ...
A compact metric space must be complete.
f(x) = 1/x is continuous but unbounded on (0,1), so (0,1) is not compact.
I'm not sure the original poster will understand using the big guns. Not understanding why "but (0,1/2),(1/4,1) IS an open cover with a finite subcover" doesn't contradict noncompactness is a misunderstanding of logic, not topology.
I am confused.
Seems like you can use (1/n, 1) to argue for (0,1) or [0,1] and say it is not compact. Because the subcover is infinite in (0,1) and [0,1].
colstat said:
I am confused.
Note that [tex]\bigcup_{i=1}^{\infty} (1/n,1)[/tex] is not a cover of [0,1] because neither 0 nor 1 are in this set.
