Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Biology
Reply
image How would I go about estimating the population of my daphnia culture? Share It Thread Tools Search this Thread image
Old Jun24-09, 02:41 PM                  #1
Sack Boy
Sack Boy is Offline:
The culture is in a standard 10 gallon tank (20"x10"x12"). I started with about 200 daphnia (<1mm to 3mm). I would like to know where I am at right now.
Old Jun24-09, 03:13 PM                  #2
jim mcnamara
jim mcnamara is Offline:
Recognitions:
Re: How would I go about estimating the population of my daphnia culture?
Estimate by sampling:
If you can safely assume:
daphnia are dispersed thru the 2400 LaTeX Code: in^-3 volume more or less randomly - ie. 90% of them are not parked on the walls or the bottom of the tank then
This is the poor man's version:
find a small clear container that has a water tight top. A 10ml test tube is great. Measure the volume of water it holds. Empty the water out.
Cover the container and open it underwater. Count the daphnia. Repeat this several
times - 10 - 15 times. Retreive the samples from different places in the tank. Record the results for each count.
Calculate the mean -
sum all of the numbers then divide that total by the number of samples. Let's pretend you got 8.2 as the value of mean. This is a large number but it does not matter.
Your tank has approximately 39.3 liters of volume. So if your sample container
was 10ml (that is .010L) then your population estimate is:
Code:
8.2 * ( 39.3 / .010 )
or
8.2 * 3930 = 32226 daphnia
image image
Reply
Tags
counting, daphnia, estimating, population
Thread Tools
Similar Threads for: How would I go about estimating the population of my daphnia culture?
Thread Thread Starter Forum Replies Last Post
question regarding homeostasis in Daphnia chris097 Other Sciences 4 Mar3-09 11:09 PM
question regarding homeostasis in Daphnia chris097 Other Sciences 0 Mar3-09 07:07 PM
07/28/08 PHD comic: 'Pop Culture!' Greg Bernhardt PhD Comics 1 Jul29-08 06:12 AM
Albertros culture Tim Benach Social Sciences 5 Apr12-06 05:27 PM
our culture, Gen X edwinwinlim Philosophy 3 Dec22-04 02:33 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
