Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Proof with the cube root of 2 Share It Thread Tools Search this Thread image
Old Jun29-09, 03:04 PM                  #1
MLeszega
MLeszega is Offline:
Hey guys. I forget where I found this problem but it goes as follows: Prove that LaTeX Code: \\sqrt[3]{2} cannot be represented in the form p+qLaTeX Code: \\sqrt{r} where p,q, and r are rational numbers.
It is easy to show that LaTeX Code: \\sqrt[3]{2} is irrational, so it cannot be put in the form m/n, where m and n are integers. However, I do not know where to go from here. I figured that since LaTeX Code: \\sqrt[3]{2} is irrational it cannot be put in any form using rational numbers, but I am not sure.
Any help is appreciated, thanks in advance.
Old Jun29-09, 03:40 PM                  #2
jgens
jgens is Offline:
Re: Proof with the cube root of 2
This seems like a homework question. If this is a homework question, you should post this in the homework forums:
http://www.physicsforums.com/forumdisplay.php?f=152
Anyway, try to prove it by assuming that 2^(1/3) can be represented in that form and derive a contradiction.
Old Jun29-09, 03:52 PM                  #3
MLeszega
It isn't a homework question, I don't go to school anymore. I did find it in a notebook that I used in school though. I just like working problems out for fun now.
Anyways, I actually did try proving it by contradiction. You get 2=(p+qLaTeX Code: \\sqrt{r} )3, which I then expanded. It didn't seem to help though.
Old Jun29-09, 04:16 PM                  #4
jgens
jgens is Offline:
First, assume that r1/2 is irrational (why is this a reasonable assumption?) Then, after expanding you get,
2 = p3 + 3(p2)(q)(r)1/2 + 3(p)(q)2(r) + (q)3(r)3/2
How might this expression help?
Old Jun30-09, 02:00 AM                  #5
MLeszega
I really don't think that assuming LaTeX Code: \\sqrt{r} is irrational is a reasonable assumption. There are plenty of rational numbers whose square roots are also rational numbers, i.e 4/9, 1/16 etc
Old Jun30-09, 03:02 AM                  #6
Moo Of Doom
Moo Of Doom is Offline:
In this situation, one usually says "without loss of generality, assume LaTeX Code: \\sqrt{r} is irrational." Here there are two cases: LaTeX Code: \\sqrt{r} is rational, and LaTeX Code: \\sqrt{r} is irrational, but one of these cases is trivial (since if LaTeX Code: \\sqrt{r} is rational, then LaTeX Code: p + q\\sqrt{r} is rational), so we don't bother with it and only look at the interesting case. This is a common phenomenon in proofs, so there is even an abbreviation for the phrase: "WLOG."
Old Jun30-09, 06:43 AM                  #7
HallsofIvy
PF Mentor
HallsofIvy is Offline:
But if LaTeX Code: \\sqrt{r} were rational here, that would imply LaTeX Code: \\sqrt[3]{2}= p+ q\\sqrt{r} is rational which you said you knew not to be true.
Old Jun30-09, 04:20 PM                  #8
MLeszega
Ok, I think I understand what you guys are talking about now. So I will set LaTeX Code: \\sqrt[3]{2} = p + qLaTeX Code: \\sqrt{r} , assume that LaTeX Code: \\sqrt{r} is irrational and show that this leads to a contradiction?
Would it be something like this: 2 = (p +qLaTeX Code: \\sqrt{r} )3. Then you expand the RHS to get:
2 = p3 +3p2qLaTeX Code: \\sqrt{r} + 3pq2r + q3r3/2
Then I guess you look at the 2nd term 3p2qLaTeX Code: \\sqrt{r} because LaTeX Code: \\sqrt{r} is irrational. Would that LaTeX Code: \\sqrt{r} term make the whole RHS irrational and therefore not equal to 2? Or is it something different?
Old Jun30-09, 05:12 PM                  #9
g_edgar
g_edgar is Offline:
Not quite. There are two irrational terms, you need to know their sum is irrational, which needs some more work.
Old Jun30-09, 05:50 PM                  #10
Petek
Petek is Offline:
Recognitions:
PF Contributor PF Contributor
Here's a hint: Rewrite the last formula in your post in the form
2 = P + QLaTeX Code: \\sqrt{r}
where P and Q are rational. Observe that r > 0 (why?) and derive a contradiction.
Old Jun30-09, 10:48 PM                  #11
MLeszega
Ok, so i can take my equation 2 = p3 + 3p2qLaTeX Code: \\sqrt{r} +3pq2r + q3r3/2
and rewrite it as:
2 = p3 + (3p2q + 3pq2LaTeX Code: \\sqrt{r} + q3r3/4)LaTeX Code: \\sqrt{r}
Set P = p3 and Q = 3p2q +3pq2LaTeX Code: \\sqrt{r} + q3r3/4
I now have the form 2 = P + QLaTeX Code: \\sqrt{r}
This is back to the original form of p + qLaTeX Code: \\sqrt{r} where we assumed that p,q and r are rational numbers. Now I can tell that Q is irrational (which would lead to a contradiction) because LaTeX Code: \\sqrt{r} and r3/4 are irrational, I just don't know how to show it mathematically.
Can you just say that if you have two irrational numbers a and b, that a + b is irrational? Like r1/2 and r3/4 are irrational, thus 3pq2r1/2 is irrational, as well as q3r3/4, then so is 3pq2r1/2 + q3r3/4 and then finally that Q is irrational?
Old Jul1-09, 02:10 AM                  #12
Moo Of Doom
You could rewrite it as LaTeX Code: 2 = \\left( p^3 + 3pq^2r \\right) + \\left( 3p^2q + q^3r \\right)\\sqrt{r} , since in this case P and Q are both actually rational.
You didn't quite do the algebra right, as you shouldn't get LaTeX Code: r^{3/4} . Remember that LaTeX Code: r^{3/2} = \\sqrt{r}^3 = \\sqrt{r}\\sqrt{r}\\sqrt{r} = r\\sqrt{r} .
Old Jul1-09, 12:38 PM                  #13
jgens
jgens is Offline:
Perhaps to help you finish the proof, using the equation as written by Moo Of Doom, you also know that r is rational.
The completed proof should look (roughly) something like this . . .
Spoiler
Suppose that 21/3 can be expressed as a number of the form, 21/3 = p + q(r)1/2 where q,p,r Є Q
Clearly, since 21/3 is irrational, (r)1/2 must also be irrational to ensure that p + q(r)1/2 is irrational.
Multiplying each side of the equation by itself three times yields the equality,
2 = p3 + 3(p)2(q)(r)1/2 + 3(p)(q)2(r) + (q)3(r)3/2
2 = [p3 + 3(p)(q)2(r))] + [3(p)2(q) + 3(r)(q)3](r)1/2
This equation is of the form 2 = P + Q(r)1/2 where P,Q,r Є Q. However, this contradicts the fact that 2 is a rational number since (r)1/2 is irrational; therefore, our initial assumption that 21/3 could be expressed in the form p + q(r)1/2 must have been incorrect. Q.E.D.
If you read the proof, it's pretty rough and the wording is awful (I guess that's what I get for trying to write it in 5 min.) but it should get the point across.
Old Jul1-09, 02:53 PM                  #14
Petek
Petek is Offline:
Recognitions:
The proof in the above spoiler is incomplete, as I'll explain in another spoiler:
Spoiler
If Q = 0, then you can't conclude that 2 is irrational. Therefore, assume that Q = 0 and derive a contradiction.
Old Jul1-09, 03:28 PM                  #15
jgens
jgens is Offline:
Bah, I suppose that's true. Should be fairly obvious why we can't have Q = 0
Old Jul1-09, 06:44 PM                  #16
Petek
Petek is Offline:
Recognitions:
Did my last post offend you? If yes, I didn't mean to do so. In any event, the case Q = 0 needs to be considered, even though it's not all that difficult.
image image
Reply
Thread Tools
Similar Threads for: Proof with the cube root of 2
Thread Thread Starter Forum Replies Last Post
Complex cube root of 1 Ferrus Precalculus Mathematics 2 Feb5-09 08:20 AM
Integral Cube Root of Cot(x) shubhangam Calculus & Beyond 10 Jul6-08 12:58 PM
Proving that cube root 7 is irrational TalonStriker Number Theory 4 Oct2-07 10:04 AM
A little inverse help cube root aisha Introductory Physics 11 Dec28-04 12:20 PM
Limit with cube and fourth root twoflower Calculus & Analysis 5 Nov19-04 05:51 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
