Unit Of Measure For My Electricity Meter
The discussion revolves around understanding the unit of measurement used by a household electricity meter, specifically focusing on the implications of the meter's dial readings and how they relate to power consumption calculations. Participants explore the relationship between meter rotations, watt-hours, and billing units, while considering practical methods for measuring electricity usage.
  • One participant initially assumes the meter measures in watt-hours but struggles to reconcile this with their usage data.
  • The participant notes the meter's dial has numbers from 0 to 90, suggesting a full rotation represents 100 units of an unknown measure.
  • They calculate potential usage ranges based on rotation times but find discrepancies, leading to confusion about the meter's scaling.
  • Another participant points out that the meter indicates "Kh 7.2," which represents the number of watt-hours per disc revolution.
  • A follow-up question arises about the rationale behind the 7.2 figure instead of a simpler 1 turn = 1 Wh.
  • Suggestions are made for using clip-on ammeters and plug-in digital power meters to obtain more accurate readings of power consumption.
  • One participant mentions that the main dial is marked in kWh and provides a specific reading, indicating the meter's current state.
  • There is a suggestion that the "3 watts" noted on the meter may refer to the power consumption of the meter itself.
Participants generally agree on the significance of the "Kh 7.2" reading for understanding the meter's measurements, but questions remain about the reasoning behind this value and its implications for calculating power usage. The discussion includes multiple viewpoints on measurement methods and the interpretation of meter readings, indicating that no consensus has been reached.
Participants express uncertainty regarding the relationship between the meter's readings and actual power consumption, particularly in terms of the scaling factor used for the dial's rotations. There are also unresolved questions about the implications of the voltage rating and how it affects billing calculations.
DaleSwanson
So I was trying to figure out how much power items at my house use. I have a standard looking power meter outside with the dial http://en.wikipedia.org/wiki/File:Electrical_meter.jpg" . I am trying to figure out though what unit the meter uses. My first instinct was watt hour, but I can't get the numbers to match.
The dial has numbers on it 0 - 90, so a full rotation is 100 units of something. It takes about 40 seconds to make a full rotation mostly everything off (like if we weren't home), and 16 seconds to make a rotation with a lot of stuff on. That works out to 90 and 225 rotations per hour. This should give a nice lower and upper bound. Last month our bill was 696 kWh, which works out to 967 watts on average.
If I assume one rotation is 100 watt hours then the monthly usage would work out to 6,480 kWh and 16,200 kWh, way too high. My next thought was that a full rotation was only one Wh. This would give us 64.8 kWh and 162 kWh, way too low. It seems be off by a factor of 6. Then I thought the meter said 240v, so it probably meters at 240 volts, if the meter did 240 volts and bill was in 120 volts that still wouldn't be right, plus I think that's pretty unlikely. I also noticed the meter says 240v 3W, so if each turn was 3Wh at 240v, and the bill was in Wh at 120v that would actually work out, but that's a pretty big stretch.
So, does anyone know how the dial on the meter measures usage?
It tells you right on the meter. That figure that says Kh 7.2 is the number of watt-hours used per disc revolution.
Ah, I see. Mine also says 7.2, so I guess my new bounds are 466 kWh and 1166 kWh, which seems right. I must say, it seems like a strange thing to do, although I suppose there is a reason behind it.
Thanks.
Strange in what way?
Where does the 7.2 come from? Why not simply use 1 turn = 1 Wh?
You should get a clip-on ammeter.
An ammeter alone will not tell you your power consumption. You need to know the current, the voltage and the power factor for an accurate reading.
The main dial is marked in KWH so at present the one in the picture is showing 86174 KWH
Run something for an hour and see how much the main meter reading changes.
The 3 watts might be the power the meter itself uses.
You can get plug in digital power meters that give a readout of Volts, Amps, Power factor, Power, KWH and KVAH and total cost.
So, you can test something like a refrigerator (which is turning on and off) over a week or so to see what it costs to run the fridge.
  • · Replies 79 ·
