Determien the resulting function of the line with points (1,2) and (3,3) and
The discussion revolves around determining the intersection of a line defined by the points (1,2) and (3,3) with the function f(x) = 2x^2 + 9. Participants are exploring how to derive the equation of the line and subsequently find the points of intersection with the given quadratic function.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss deriving the equation of the line from the two points and express uncertainty about the correctness of their calculations. Questions about the intersection points and the validity of the resulting equations are raised.
The discussion is ongoing, with participants attempting to clarify their understanding of the problem and the algebra involved. Some guidance has been offered regarding the correctness of the derived equations, and there is an exploration of the implications of the results obtained.
There is mention of potential algebraic errors in the derived equations, and participants are questioning the assumptions made in their calculations. The presence of a quadratic function and the nature of the intersection are also under scrutiny.
cruisx
Determien the resulting function of the line with points (1,2) and (3,3) and...
hi guys how are you, i am having a little trouble solving the question adn was wondering if some of you could give me a hand?
Determine the resulting function of the line with points (1,2) and (3,3) and f(x) = 2x^2 + 9 intersect?
Now idk how to solve this as its been a while since i did any math but i tried to put it into an equation of a line and i got y=1/2x+3/2 but i know that's not right as its for an equation of a line =/. I know i need to use the two points to make an equation and then do this
equation = 2x^2 + 9 but i don't know how to solve the two points and get an equation.
Sorry if I'm being obtuse, but are trying to find the intersection between the line with points (1,2) and (3,3) and the function f(x) = 2x2 + 9? If so, you've gotten the equation for the line correct, now all you would need to do is solve for the intersections. If I've misinterpretted the question, hopefully you wouldn't mind clarifying for me.
I am trying to find the intersection so i guess i am right. So i would do this right?
1/2x + 3/2 = 2x^2 + 9
and that would result to
-2x2 + 1/2x + 21/2 = 0
Is this correct? Also could you see if this is correct as well?
I am given a y-intercept of 0 and a point of (2,2) and the equation of the line i got is this
y = 1x + 0
is that correct?
Well, your new quadratic equation isn't quite right (check the algebra)! The equation that you should get never intersects the x-axis. What does this suggest?
why not? what's wrong with it? which one are u referring too?
ohh i think you are right, should it be - 22 + 1/2x - 15/2 ??
  • · Replies 23 ·
  • · Replies 18 ·
