Why is the Rayleigh Criterion not a definitive resolution limit for microscopes?
  • Context: Graduate
  • Thread starter Thread starter KFC
    Microscope Resolution
The discussion revolves around the Rayleigh criterion and its implications for the resolution limits of microscopes. Participants explore the relationship between wavelength, aperture size, and angular separation in the context of diffraction-limited resolution, questioning the definitive nature of the Rayleigh criterion in various scenarios.
  • One participant suggests that increasing the angle (theta) should improve resolution, proposing that long wavelength light might be preferable, despite texts indicating short wavelengths are favored.
  • Another participant clarifies that D represents the separation between two points, emphasizing that theta should be minimized for better resolution.
  • A subsequent reply acknowledges the confusion regarding D and theta, confirming that D is indeed the aperture size and that theta relates to the angular separation of resolvable points.
  • Further clarification is provided that the formula presented is for diffraction-limited resolution, reiterating the importance of minimizing theta.
  • One participant questions why the minimum separation of diffraction patterns is equated with the minimum separation of objects, seeking deeper understanding of the criterion's application.
  • Another participant introduces the idea that resolution criteria are based on signal-to-noise ratios and mentions alternative criteria, such as Sparrow's criterion, highlighting that the Rayleigh limit applies to incoherent points and may not be applicable in all lighting conditions.
  • The discussion concludes with a note that terms like "maximum resolution" are not absolute limits, suggesting a more nuanced understanding of resolution in microscopy.
Participants express varying interpretations of the Rayleigh criterion and its implications, with no consensus reached on its definitive nature as a resolution limit. Multiple competing views regarding the relationship between wavelength, aperture, and resolution persist throughout the discussion.
Participants highlight potential limitations in understanding the Rayleigh criterion, including assumptions about light coherence and the applicability of different resolution criteria in various contexts.
KFC
From Rayleigh criterion, the resolution of microscope is given by
[tex]\sin\theta = 1.22\frac{\lambda}{D}[/tex]
where D is the separation b/w two objects. Suppose D is constant, image and object distances are fixed, if we want to increase the resolution, we should increase the angle (theta) right? So we should use long wave-length light instead of short one? But in the text, they said short wavelength is preferred (in some case even use electron wave), why is that?
Science news on Phys.org
Isn't D the aperture of the objective?
theta is the minimum separation between two points (on the object) - so you want to make theta as small as possible
Oh! D is the separation between two points (for example, the distance between to pinholes) and I forget that theta estimates the size of zero-order disc of the diffraction pattern, so we should make it as small as possible. What was I thinking!? :(
mgb_phys is correct. D is the apperture size. The formula that you present is for the diffraction limited resolution. θ is the minimum angular separation between two points that can be resolved.
Yes, D is the aperture size. Thanks for pointing that out. I still have a question. From Rayleigh's criterion, at small angle approxmiation, the limit of resolution gives
[tex]\theta = 1.22\frac{\lambda}{D}[/tex]
where [tex]\theta[/tex] gives the minimum angular separation of two patterns that can barely be resolved. That is, this criterion is applied on the diffraction pattern. But in the text, this also works on objects. Namely, the minimum angular separation of two objects that can barely be resolved is also equal to [tex]\theta = 1.22\frac{\lambda}{D}[/tex], why MINIMUM SEPARATION OF DIFFRACTION PATTERNS = MINIMUM SEPARATION OF OBJECTS?
Again, these criteria are based on heuristic arguments about how much signal-to-noise is required to differentiate an object from background. The Rayleigh criterion claims that neighboring airy discs can be separated if the central dip from the combined pattern is 20% below the maximum intensity. There are many resolution criteria- Sparrow's criterion is another. There are still more for pixelated detectors.
Even moreso, the Rayleigh limit is for two mutually incoherent points, something that may not be the case for a scene illuminated with partially coherent light.
The bottom line is that "maximum resolution" or "resolution limit" or all those other marketing buzzwords are not hard limits.
