Why Is the Hermiticity of the Density Operator Important in Quantum Mechanics?
The discussion centers on the importance of the Hermiticity of the density operator in quantum mechanics, exploring both its mathematical and physical implications. Participants examine the significance of the eigenvalues of the density matrix and their relationship to probabilities, as well as the application of the density operator in specific quantum systems.
  • Some participants assert that the eigenvalues of the density matrix must be real and non-negative, which implies that the density matrix must be Hermitian.
  • One participant questions the physical significance of the diagonal elements of the density matrix before diagonalization.
  • Another participant discusses the application of the density operator in a two-level system and raises a question about the form of the time evolution of the density operator.
  • Some participants argue that real eigenvalues alone do not imply Hermiticity, referencing the definition of the density matrix as a sum over states.
Participants express differing views on the implications of real eigenvalues for Hermiticity, indicating that multiple competing views remain regarding the necessity and significance of Hermiticity in the context of the density operator.
Some assumptions about the definitions and properties of the density matrix may not be fully explored, and the discussion includes unresolved mathematical steps regarding the time evolution of the density operator.
KFC
Hi there,
In all text of QM I have, they tells that the density operator is hermitian. But without considering the math, from the physics base, why density operator must be hermitian? What's the physical significane of the eigenvalue of density matrix?
Thanks
Eigenvalues of the density matrix are probabilities. They clearly must be real, which is why the matrix must be hermitian. (In addition, they also must be non-negative and not larger than 1.)
Thanks. So before diagonalization, the diagonal elements of density matrix don't tell anything , right?
Well, I understand now how the diagonalized density matrix works. But for the following case how do I use it? For example, I have a two-level system without interaction, and hamiltonian gives
[tex]H|\Psi_n\rangle = \hbar\omega_n |\Psi_n\rangle[/tex]
Now I consider the Heisenberg equation of the density operator
[tex]\dot{\rho} = -\frac{i}{\hbar}[H,\rho][/tex]
to findout the element of [tex]\dot{\rho}_{nm}[/tex], I apply an eigenstate of H on both side
[tex]\dot{\rho}|\Psi_i\rangle = -\frac{i}{\hbar}(H\rho - \rho H)|\Psi_i\rangle<br /> = -\frac{i}{\hbar}(H-\omega_i)\rho|\Psi_i\rangle[/tex]
So, what is [tex]\rho|\Psi_i\rangle[/tex]? In the text, it gives
[tex]\dot{\rho}_{nm} = -i\omega_{nm}\rho_{nm}[/tex] ?
Real eigenvalues does not imply hermiticity - for example, look at "[URL Hermiticity of the density matrix follows from its definition, which is
[tex] \rho := \sum_k p_k |\psi_k\rangle\langle\psi_k|[/tex]
where [tex]p_k[/tex] is the probability that system will be found in the state [tex]\psi_k[/tex] (states [tex]\psi_k[/tex] can be arbitrary possible states of the system).
