| Thread Closed |
Optic help |
Share Thread | Thread Tools |
| Aug7-09, 09:53 PM | #1 |
Optic help
1. Light from a helium-neon laser (l=650 nm) is used to illuminate two narrow slits. The interference pattern is observed on a screen 2.12 m behind the slits. Twelve bright fringes are seen, spanning a distance of 49 mm. What is the spacing (in mm) between the slits?
lamda=650x10^-9 m L=2.12 m Ym=49x10^-3 m= 12 d=solving for d=mL(lamda)/Ym= .03375 mm why doesnt that work? 2. A 0.24-mm-diameter hole is illuminated by light of wavelength 476 nm. What is the width (in mm) of the central maximum on a screen 1.5 m behind the slit How do I do this since it has a diameter, I can't find it in the book anywhere 3. A 578 line/mm diffraction grating is illuminated by light of wavelength 599 nm. How many bright fringes are seen on a 2.73-m-wide screen located 3 m behind the grating d=1/(578x 10^-3) lamda=599x10^-9 Ym=2.73 m L=3 m m=Ym*d/(lamda*L) All these ways of solving them doesn't work why is that? |
| Aug8-09, 03:42 AM | #2 |
Mentor
If there one bright fringe, that would be m=0. Two bright fringes would be m=0 and 1. Three bright fringes would be 0, 1, and 2. . . . Twelve bright fringes have m = 0 through ___ ? Here is more info: http://hyperphysics.phy-astr.gsu.edu...irapp2.html#c2 http://www.physicsforums.com/library...tem&itemid=192 |
| Aug8-09, 10:39 AM | #3 |
Sorry about the equation problem I copied it from an email I had sent and it didn't excatly work as planned.
1. m=0 with 12 bright fringes m=11 correct? 2.I'll look at the sights you gave me and if I have anymore problems I will post on here, thank you 3.I divde the d in half correct? I found an example, but I just don't understand why? |
| Aug8-09, 10:57 AM | #4 |
Mentor
Optic help578 lines/mm, so d is (1/578) mm = ____ m? |
| Aug8-09, 11:07 AM | #5 |
I did edit it, thank you for telling me I could.
1. I got it now I just rushed things 2. y=L*m*lamda/d where d is the diameter, L is the distance behind, lamda is the wavelength (obviously), m is bright fringes. How do I discover how many bright fringes there are there so I can do this I assumed one, but this is wrong. Oh also Y is the width because it is the displacement on the Y axis. 3. 1.73 m? |
| Aug8-09, 11:12 AM | #6 |
Mentor
(1/578) mm = (1/578) x 10-3 mNotice the answer is a lot smaller than a meter, because both (1/578) and 10-3 are small numbers. |
| Aug8-09, 11:13 AM | #7 |
Oh what I was doing was 1/(578x10^-3)
| Aug8-09, 11:17 AM | #8 |
2. Can you offer so more advice please
3. so doing it the correct way with d = 1/578 x 10^-3 m Ym=2.12 m lamda= 599x 10^-9 m L= 3 m all units cancel leaving basically bright fringes, plug and chug using the equation m=(Ym*d)/(lamda*L) |
| Aug8-09, 08:27 PM | #9 |
Mentor
1. y is the radius of the diffraction pattern on the screen. 2. m is a number you can get from the "m values" table at http://hyperphysics.phy-astr.gsu.edu...irapp2.html#c2A hint: the diameter of the central bright fringe is really the diameter of the 1st minimum in the diffraction pattern. |
| Aug8-09, 08:34 PM | #10 |
Mentor
| Aug8-09, 09:12 PM | #11 |
Recognitions:
| Aug8-09, 10:05 PM | #12 |
Mentor
If the screen is off-center, there can be an even number of fringes appearing on it.
| Aug8-09, 11:11 PM | #13 |
Recognitions:
| Aug9-09, 07:59 AM | #14 |
Mentor
(Problem #1)
The central maximum will be the bright fringe directly in front of the slits, no matter what the screen position is. I am (for now) going on the assumption that the problem was correctly copied when posted here. For the small angles being considered, it does not matter whether the screen contains the m=0 through m=11 fringes, or the m=-5 through m=6 fringes. As long as 12 fringes close to the central maximum are visible, the small-angle approximation holds and the answer will be the same. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Optic help
| My old question on Optic | Introductory Physics Homework | 2 | ||
| need help on an optic question | Introductory Physics Homework | 2 | ||
| optic | Classical Physics | 2 | ||
| Optic question | Introductory Physics Homework | 4 | ||
| optic and velocity | Astrophysics | 3 | ||
