Solve Lagrangian Homework Problem: Tricky Motion of Mass C
  • Thread starter Thread starter s.g.g
    Lagrangian
The discussion focuses on solving a Lagrangian mechanics problem involving three identical masses (A, B, and C) connected by springs with spring constant k, subjected to a driving force F=F0*cos(omega*t). The kinetic energy term is defined as T=0.5*m*((x1dot)^2 + (x2dot)^2 + (x3dot)^2), while the potential energy is expressed as V=0.5 k [(x1-x2)^2 + (x2-x3)^2]. The incorporation of the driving force into the potential is clarified by adding -F(t)x1 to V, addressing the uncertainty regarding equilibrium positions of the masses.
  • Understanding of Lagrangian mechanics and the Euler-Lagrange equation.
  • Familiarity with kinetic and potential energy formulations in mechanical systems.
  • Knowledge of harmonic oscillators and spring constants.
  • Basic grasp of differential equations and their application in motion analysis.
  • Study the derivation of the Euler-Lagrange equation in detail.
  • Learn about the effects of external forces on Lagrangian systems.
  • Explore the concept of equilibrium positions in multi-body systems.
  • Investigate numerical methods for solving differential equations in mechanical systems.
Students and professionals in physics, particularly those studying classical mechanics, as well as engineers and researchers working on dynamic systems involving multiple interacting bodies.
s.g.g
A system consists of 3 identical masses (A,B & C) in a line, connected by 2 springs of spring constant k. Motion is restricted to 1 dimension. at t=0 the masses are at rest. Mass A is the subjected to a driving force given by:
F=F0*cos(omega*t)
Calculate the motion of C
L=T-V, Euler lagrange equation.
I figured that the easiest way to do this is to write a lagrangian and solve for the equation of motion for the masses.
I denoted the initial positions of the masses x1, x2 and x3 respectively.
the kinetic energy term for the lagrangian then becomes
T= 1.5*m*((x1dot)^2 + (x2dot)^2 + (x3dot)^2)
For the potential, i have stated that the distance between the masses at equilibrium is equal to J. Hence the potential due to the springs is:
V= k(x1^2 + 2*x2^2 - 3*x2*x1 - x2*x3 + x1*x3 + J(x1+x3-2*x2)
I am unsure if this is correct and i have no idea how to incorporate the driving force into the equation. Any ideas?
Your kinetic term should have a coefficient of 0.5, not 1.5. If we choose to measure each position from its own equilibrium point, then we can set J=0. Then the potential from the springs should be V = 0.5 k [(x1-x2)^2 + (x2-x3)^2]. You can take the force into account by adding -F(t)x1 to V, because a force is minus the gradient of the potential.
i was uncertain whether i could ascribe an equilibrium position to each mass as it is determined by its position relative to the adjacent masses rather than a fixed point in space. Hence it is constantly changing. that is why i thought i had to introduce the value J. Is this wrong?
  • · Replies 22 ·
  • · Replies 0 ·
