Curl of - \frac{1}{\rho} \vec \nabla p
  • Context: Graduate
  • Thread starter Thread starter John Creighto
    Curl
The discussion focuses on deriving the vorticity equation, specifically addressing the term +\frac{1}{\rho^2}\vec \nabla \rho \times \vec \nabla p. The user confirms the left-hand side of the equation is correct but struggles with the right-hand side. They utilize the vector identity \nabla \times (\psi\mathbf{A}) = \psi\nabla \times \mathbf{A} - \mathbf{A} \times \nabla\psi to show that - \nabla \times \frac{1}{\rho} \vec \nabla p simplifies to \frac{1}{\rho^2} \nabla \rho \times \vec \nabla p, confirming the equivalence to the vorticity equation found on Wikipedia.
  • Understanding of vector calculus identities, specifically curl and gradient operations.
  • Familiarity with fluid dynamics concepts, particularly the vorticity equation.
  • Knowledge of the physical significance of density \rho and pressure p in fluid mechanics.
  • Proficiency in applying the chain rule in vector calculus.
  • Study the derivation of the vorticity equation in fluid dynamics.
  • Learn about vector calculus identities and their applications in physics.
  • Explore the implications of the curl of a gradient being zero in fluid mechanics.
  • Investigate the relationship between pressure gradients and vorticity in fluid flow.
Students and professionals in fluid dynamics, physicists, and mathematicians interested in advanced vector calculus applications in fluid mechanics.
John Creighto
I'm trying do derive the vorticity equation
[tex]\begin{align}\frac{D\vec\omega}{Dt} &= \frac{\partial \vec \omega}{\partial t} + (\vec V \cdot \vec \nabla) \vec \omega \\<br /> &= (\vec \omega \cdot \vec \nabla) \vec V - \vec \omega (\vec \nabla \cdot \vec V) + \frac{1}{\rho^2}\vec \nabla \rho \times \vec \nabla p + \vec \nabla \times \left( \frac{\vec \nabla \cdot \underline{\underline{\tau}}}{\rho} \right) + \vec \nabla \times \vec B<br /> \end{align}[/tex]
based on the notes give here.
I agree with the result obtained for the LHS of the equation but I am having trouble with one term on the right hand side of the equation:
[tex]+ \frac{1}{\rho^2}\vec \nabla \rho \times \vec \nabla p[/tex]
which as far as I can understand should be the curl of:
[tex]- \frac{1}{\rho} \vec \nabla p[/tex]
Looking up useful vector identities:
[tex]\nabla \times (\psi\mathbf{A}) = \psi\nabla \times \mathbf{A} - \mathbf{A} \times \nabla\psi[/tex]
I don't see how to obtain this term.
I've figured it out:
This is nearly equivalent to the form of the vorticity equation shown in Wikipedia except for this term:
[tex]- \nabla \times \frac{1}{\rho} \vec \nabla p[/tex]
The following identity is needed:[tex]\nabla \times (\psi\mathbf{A}) = \psi\nabla \times \mathbf{A} - \mathbf{A} \times \nabla\psi[/tex]
Therefore:[tex]- \nabla \times \frac{1}{\rho} \vec \nabla p = \frac{1}{\rho} \nabla \times \vec \nabla p - \vec \nabla p \times \nabla \frac{1}{\rho}[/tex]
but since the curl of a gradient is equal to zero:[tex]- \nabla \times \frac{1}{\rho} \vec \nabla p = - \vec \nabla p \times \nabla \frac{1}{\rho}[/tex]
Now applying the chain rule:[tex]- \nabla \times \frac{1}{\rho} \vec \nabla p = - \vec \nabla p \times \frac{1}{\rho^2} \nabla \rho[/tex]
Reversing the order of the cross product changes the sign. Consequently:
[tex]- \nabla \times \frac{1}{\rho} \vec \nabla p = \frac{1}{\rho^2} \nabla \rho \times \vec \nabla p[/tex]
http://earthcubed.wordpress.com/2009/08/25/64/
  • · Replies 32 ·
  • · Replies 23 ·
