Can Anti-Gravity Globes Work Upside Down?
  • Context: High School
  • Thread starter Thread starter LSteel
    Anti-gravity
The discussion revolves around the feasibility of using magnets to suspend objects, specifically focusing on the concept of "anti-gravity globes" and whether they can function when inverted. Participants explore various designs and mechanisms for achieving magnetic suspension, as well as the challenges associated with lighting a suspended bulb wirelessly.
  • One participant questions if an object can be suspended with its base on top, suggesting that the design of the gadget will influence its feasibility.
  • Another participant explains that for stable suspension, forces must balance at the suspension point, and deviations must be countered by a restoring force, which presents challenges in an inverted orientation.
  • A suggestion is made to use an electromagnet with controllable current to maintain stability, requiring distance sensing between the globe and the magnet.
  • Participants discuss the potential for wireless energy transfer to light a suspended bulb, with one proposing electromagnetic induction as a theoretical method, while acknowledging its inefficiency.
  • Another participant raises concerns about the practicality of current flow in a closed circuit for conventional heating and discusses the principles of dielectric heating in microwave ovens.
  • Resistive heating via induction is mentioned as a possibility, with references to Joule heating and its mechanisms.
  • One participant expresses interest in the aesthetic appeal of a suspended bulb, emphasizing that they are not looking for practical applications on a large scale.
  • Another participant notes that the efficiency of near-field resonant induction could be acceptable if the transmitter is appropriately sized and positioned.
  • Concerns about the stability of the system when inverted are reiterated, highlighting the need for software control to manage the bulb's position relative to the magnet.
Participants express varying opinions on the feasibility of suspending objects with the base on top and the methods for achieving wireless energy transfer. There is no consensus on the practicality or efficiency of the proposed solutions, and multiple competing views remain regarding the mechanisms and challenges involved.
Participants mention limitations related to the efficiency of wireless energy transfer methods and the challenges of maintaining stability in an inverted orientation. The discussion includes unresolved technical details and assumptions about the designs being considered.
Readers interested in magnetic suspension technologies, wireless energy transfer, and the theoretical aspects of electromagnetism may find this discussion relevant.
LSteel
"anti-gravity globe" question
I had a question about the anti-gravity globes, and used to wonder if they would still work if flipped upside down, I now realize they won't when I actually thought about it.
However, is there anyway to suspend an object using magnets with the base on top? I looked on google for a little while and didn't find anything. I've lurked here for a few months and figured this would be the best place to ask.
the globe I'm talking about http://www.thinkgeek.com/geektoys/science/98b8/?cpg=ab
Sorry if this is the wrong section
What do you mean with "tha base on top"? It will depend on the desing of the gadget.
I can imagine what you're thinking and I guess it's possible but please try to make yourself a little bit more clear so that I may help you :)
I assume you mean that the globe is suspended below magnet rather than above it. To be stable the forces must balance at the suspension point and any small deviations by the globe from this point must be countered by a restoring force. This latter presents a difficulty with inverted orientation. The problem is similar to that encountered in trying to balance a broomstick (or inverted pendulum). The balance point is metastable. The greater the separation between the magnets, the weaker magnetic field gets, and vice versa. A constant strength magnet in the base will not do the trick. The globe will either fall to the floor or rise up to the magnet.
The obvious solution is to use a non-constant strength magnet. Use an electromagnet with a controllable current flow. Reduce / increase the current if the globe gets too close to / too far from the magnet. This in turn means the device needs to sense the distance between the globe and the magnet and feed this back to the current control.
Sorry about that zaphys. I was picturing a lightbulb suspended about an inch below the ceiling with the "base" above the drywall. So when you looked at it all you would see if just a hanging lightbulb. After that I'd want to wirelessly transfer energy to it. It would just be one lightbulb, because I know how inefficient it still is.
And D H, I understand what you're saying, the globe I linked says it uses microprocessors to constantly judge where the globe is and adjust the magnet, so I would need to do something along those lines?
... is there anyway to suspend an object using magnets with the base on top?
Seems very likely.
The
... precisely placed magnet located at the inside top of the globe.
in the illustrated orientation adds to the stability/orientation of the globe and that stability and location relative to the base is reflected in the software control.
So inverting the contraption would now place the magnet next to the base to keep north up; likely control software would have to be modified.
How would you in theory light a freely suspended bulb? That requires a complete circuit and offhand I can't think of a way to accomplish that...
How about by electromagnetic induction?The bulb filament could act like the secondary of a transformer.It would be very inefficient and difficult to do in practise but in principle it would work.
Am unsure exactly sure just how 'electromagnetic induction" works...but there seems no way for current to flow...as in a closed circuit...for conventional heating...
I checked out Wikiepedia on microwave ovens since if you heat something enough it will get hot enough to emit electromagnetic radiation...maybe visible light. Wiki sez:
Water, fat, and other substances in the food absorb energy from the microwaves in a process called dielectric heating. Many molecules (such as those of water) are electric dipoles, meaning that they have a positive charge at one end and a negative charge at the other, and therefore rotate as they try to align themselves with the alternating electric field of the microwaves. This molecular movement represents heat which is then dispersed as the rotating molecules hit other molecules and put them into motion
I guess such metals do get hot in microwave ovens...but unsure just how...I checked tungston,too, and it sure has a LOT of applications I never considered..'''.but am unsure if it's molecules are dipoles...
Occurred to me resistive heating might work ok via induction...looked up joule heating in wiki and it says:
It is now known that Joule heating is caused by interactions between the moving particles that form the current (usually, but not always, electrons) and the atomic ions that make up the body of the conductor. Charged particles in an electric circuit are accelerated by an electric field but give up some of their kinetic energy each time they collide with an ion. The increase in the kinetic or vibrational energy of the ions manifests itself as heat and a rise in the temperature of the conductor. Hence energy is transferred from the electrical power supply to the conductor and any materials with which it is in thermal contact.
Sounds like it...anybody have better insights??
I'll have to look further into wireless energy transfer to get more specifics on it, at the moment though I'm just exhausted from a LONG day at school. First days of the semester suck.
I understand that the efficiency would be a joke, I'm certainly not looking to do this on a wide scale in my house or anything like that, I just thing it would be pretty awesome looking to have an "Edison era" light bulb suspended by the ceiling with no wires being lit up.
But thanks for the advice on the possibility of the bulb being suspended, without that I didn't need to really research any further into my little project.
Dadface posted:
I forgot to mention that Wiki also discusses the relative (in)efficiency of microwave (ovens)...(electromagnetic induction) so if anyone is interested in thos losses you can get an idea there...
The efficency of near-field resonant induction is quite good. If you can have a transmitter larger than the gap to the bulb (which you can put in the ceiling) an can control the position and distance to the bulb the efficiency isn't a problem.
The stability of the system is trickier. By having a globe levitated over a magnet as the globe falls it moves into a stronger field and is lifted up - so naturally stable - even then you need software control to stop the globe moving out of the field sideways. Hanging below the magnet you would need to control the power - so that if the bulb moved down (away from the magnet) you could sense this and increase the field to lift it back up.
  • · Replies 18 ·
  • · Replies 16 ·
