2. Order Linear Inhomogenous Recurrence Relations with Constant Coefficients
The discussion revolves around the solution of a second-order linear inhomogeneous recurrence relation with constant coefficients, specifically the form \( a_n = c_1a_{n-1} + c_2a_{n-2} + f(n) \). Participants explore the structure of solutions, particularly the relationship between homogeneous and inhomogeneous solutions.
  • One participant suggests that the solution can be expressed as \( U_n = V_n + g(n) \), where \( V_n \) is the solution to the corresponding homogeneous equation.
  • Another participant reformulates the recurrence relation and demonstrates that if \( g(n) \) is a solution to the inhomogeneous equation, then \( V(n) \) must satisfy the homogeneous equation.
  • Some participants express skepticism about the assumption that \( g(n) \) must be a solution to the inhomogeneous equation for the proposed form to hold.
  • There is a contention regarding the validity of using linear combinations of solutions, with one participant asserting that such combinations only apply to homogeneous equations.
  • Several participants discuss the implications of assuming \( g(n) \) is a solution, with one providing a detailed algebraic manipulation to illustrate the reasoning behind this assumption.
Participants express differing views on the necessity of \( g(n) \) being a solution to the inhomogeneous equation for the proposed solution form to be valid. The discussion remains unresolved, with multiple competing interpretations of the conditions required for the solutions.
Some participants note that the assumption regarding \( g(n) \) is critical but not explicitly stated in the original problem. There is also a discussion about the limitations of linear combinations in the context of homogeneous versus inhomogeneous equations.
e(ho0n3
I need to show that the solution of
[tex]a_n = c_1a_{n-1} + c_2a_{n-2} + f(n)[/tex] (1)
is of the form
[tex]U_n = V_n + g(n)[/tex] (2)
where [itex]V_n[/itex] is the solution of a 2. order linear homogenous recurrence relation with constant coefficients.
Could I use the argument that if (2) is a solution to (1), then there are constants b and d such that [itex]bU_{n-1} + dU_{n-2}[/itex] is also a solution to (1)? This is the only thing I can think of (and am familiar with since the book uses this argument in two proofs). I don't know anything about generating functions so I don't know what to do.
Mathematics news on Phys.org
Write your equation as:
[tex]a_{n}-c_{1}a_{n-1}-c_{2}a_{n-2}=f(n) (1)[/tex]
Assume g(n) is a solution of (1)
Let U(n) be another solution of (1)
Let V(n) be the difference, V(n)=U(n)-g(n)
Then we have:
[tex]V_{n}-c_{1}V_{n-1}-c_{2}V_{n-2}=U_{n}-c_{1}U_{n-1}-c_{2}U_{n-2}-(g_{n}-c_{1}g_{n-1}-c_{2}g_{n-2})=[/tex]
[tex]f(n)-f(n)=0[/tex]
That is, V(n) is a solution of the associated homogenous recurrence relation.
Then we have:
Interesting. I'm not convinced though since you had to assume g(n) is a solution to (1). If it isn't, then what?
That was an (unmentioned) condition of the original problem: if Vn is a solution to the corresponding homogeneous equation then Vn+ g(n) is a solution to the inhomgeneous equation if and only if g(n) is a particular solution to the inhomogeneous equation.
To answer the poster's original question: "Could I use the argument that if (2) is a solution to (1), then there are constants b and d such that [itex]bU_{n-1} + dU_{n-2}[/itex] is also a solution to (1)?", No, you can't because it is not true: Pluginging [itex]bU_{n-1} + dU_{n-2}[/itex] into the equation would give (b+d)f(n), not f(n). A linear combination of solutions is a solution only for homogeneous equations.
I really wish I had the ability to figure this stuff out, like you seem to do. I still don't follow they line of logic being employed to determine that g(n) must be a solution in order for Vn+ g(n) to be a solution and vice versa.
I came to this conclusion as well, but I wasn't really sure so I decided to post the problem here.
Suppose V(n) is a solution of the hom. equation.
Assume that V(n)+g(n) is a solution of the inhom. equation.
Then it follows that g(n) itself is a solution of the inhom. solution.
The converse:
Assume that g(n) is a solution of the inhom. equation.
It then follows that V(n)+g(n) is a solution of the inhom. equation.
To expand on what arildno just said: Suppose A(xn) is some linear recurrance relation- that is A(xn)= axn+2+ bxn+1+cxn, etc. A "homogeneous" equation is of the form A(xn)= 0. It's
easy to show that any linear combination of solutions is still a solution: If Vn and Un are satisfy A(Un)= 0 and A(Vn)= 0 then A(pUn+ qVn)= 0 also for any number p and q. "Second order" or "constant coefficients" are not needed but "linear" is. You simply use the definition of A (or more generally the definition of "linear") to show that A(pUn+qVn)= p A(Un)+ q A(Vn)= p(0)+ q(0)= 0.
Now, suppose Rn and Sn are both solutions to the non-homogeneous equation A()= f(n)- that is, that A(Rn)= f(n) and A(Sn)= f(n). Again, using the fact that A is linear, A(Rn- Sn)= A(Rn)- A(Sn)= f(n)- f(n)= 0.
That is, the difference between Rn and Sn satisfies the homogeneous equation: Rn- Sn= Un for some U satisfying the homogeneous equation. That is the same as saying Rn= Un+ Sn.
The exact same this is true, incidently, for homogenous and non-homogeneous differential equations.
The converse:
I still don't see how the consequent follows from the antecedent. Here is my reasoning on why g(n) must be assumed to be a solution of the inhom. equation so that Vn + g(n) is a solution:
We know that [itex]V_n[/itex] is a solution to the correspoding homogenous equation, so this implies that [itex]V_n = c_1V_{n-1} + c_2V_{n-2}[/itex]. If [itex]V_n + g(n)[/itex] is a solution to the inhomogenous equaiton, then
[tex]\begin{align*}<br /> V_n + g(n) &= c_1(V_{n-1} + g(n-1)) + c_2(V_{n-2} + g(n-2)) + f(n) \\<br /> &= c_1V_{n-1} + c_2V_{n-2} + c_1g(n-1) + c_2g(n-2) + f(n) \\<br /> &= V_n + c_1g(n-1) + c_2g(n-2) + f(n)<br /> \end{align}[/tex]
Hence, [itex]g(n) = c_1g(n-1) + c_2g(n-2) + f(n)[/itex] which statisfies the inhom. recurrence relation and so g(n) must be a solution of it. Maybe this is what you guys have been saying all along, but I'm just to dense to see it.
