Inverse function containing square root
The discussion revolves around finding the inverse of the function f(x) = -x² - 2x + 3, defined for x < -1, and specifically exploring the relationship between the function and its inverse, particularly in terms of composition and notation.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive the inverse function and explore the composition f⁻¹(f(x)). They express confusion regarding the substitution process and the implications of absolute values in their calculations.
  • Some participants question the notation used for the inverse and composition of functions, clarifying the difference between product notation and composition notation.
  • Others suggest reconsidering the absolute value aspect of the square root in the context of the function's domain.
The discussion is active, with participants providing clarifications on notation and addressing the original poster's confusion regarding the calculations. There is acknowledgment of the importance of the modulus in the context of the function's domain, indicating a productive direction in the conversation.
Participants note the constraints of the function's domain and the implications for the inverse function, as well as the potential for confusion arising from different notational conventions in mathematical literature.
ephedyn
Given f(x) = -x2 - 2x + 3, x < -1
Find f-1.
Find f-1f.
Nil.
Actually I worked out much of the question already, and I already know that f-1f: x -> x. The problem is, I can't seem to get f-1f(x) = x on substitution. Here goes:
Let y = -x2 - 2x + 3
4 - y = (x+1)2
x = - 1 +/- sqrt(4-y)
Since the domain of f is the range of f-1, we have
f-1: x -> -1 - sqrt(4-x), x < 4
Consider f-1(x) = -1 - sqrt(4-x)
Substituting f(x),
f-1(f(x)) = -1 - sqrt(x2+2x+1) = -x-2
OK, here's the problem. I know I will get f-1f(x)= x if sqrt(x2+2x+1) = -x-1 and I understand that
x2+2x+1 = (x+1)2 = (-x-1)2
but my reasoning here doesn't reject -x-2 as a valid answer. Where is the mistake in my working?
ephedyn said:
Substituting f(x),
This is not correct.
[tex]-1 - \sqrt{x^2 + 2x + 1} = -1 - \sqrt{(x+1)^2} = -1 - |x + 1|[/tex]
Since the domain of [itex]f^{-1}\circ f[/itex] is the same as the domain of f, giving only negative values for the expression in the absolute value function, there is only one branch of the absolute value function in use, which should allow you to derive the correct identity.
Ahhh I totally forgot about the modulus. Thanks a lot!
Find f-1f.
Another point that should be mentioned has to do with your notation. f-1f means the product of the inverse and the original function. That's different from the composition of the two functions, which is represented this way:
The composition of these two functions is defined this way:
[itex](f^{-1}\circ f)(x)[/itex] = f-1(f(x))
Actually, I've seen the circle notation in some texts and product notation in other texts to reflect their relation to real number multiplication as is done in abstract algebra. The circle notation is not required.
In abstract algebra you have structures such as groups in which you have a set of objects and an operation. The operation can be normal addition or multiplication, or can be function composition. In any case, the operation is well-understood.
If you're working with functions gf usually means the product of two functions, while g[itex]\circ[/itex] f normally means function composition. To avoid confusing the two operations, a small circle is usually used. That was my point.
