| Thread Closed |
Gravitational Force Vector exerted by 2 charged objects |
Share Thread | Thread Tools |
| Sep16-09, 09:18 PM | #1 |
Two thin hollow plastic spheres, about the size of a ping-pong ball with masses (m1=m2 = 2e-3 kg) have been rubbed with wool. Sphere 1 has a charge q1 = -4e-9 C and is at location < 40e-2, -20e-2, 0 > m. Sphere 2 has a charge q2 = -6e-9 C and is at location < -50e-2, 40e-2, 0> m I've already calculated Relative Position Vector: <-90e-2, 60e-2, 0> Distance between q1 and q2: 1.0816653 m Unit Vector: <-.8320502943, .5547001962, 0> Magnitude of gravitational force exerted on q2 by q1: 2.29059829e-16 The Electrostatic Force between the two objects: 1.84615e-7 Questions: 1) What is the gravitational force (vector) exerted on q2 by q1? 2) What is the electric force (vector) exerted on q2 by q1? 2. Relevant equations Fnet = G * [(m1 * m2)/r^2] Felec = k * [(q1 * q2)/r^2] 3. The attempt at a solution For question 1, I took each separate component of the unit vector and divided it by the magnitude. i.e. <(-.8320502943 / 2.29059829e-16), (.5547001962 / 2.29059829e-16), 0> For question 2, I didn't know where to start, assuming I needed the answer to question 1. |
| Sep17-09, 06:47 AM | #2 |
Hey there NAl101
![]() Why do you think that questions 1 and 2 are related? You have already written the formula Felec = k * [(q1 * q2)/r^2] which gives the electrostatic force bewteen two point charges (and I think it is safe to say that we can treat these as point charges). Perhaps it is the sign of the charges that is troubling you? If so, I would simply treat the formula with their absolute values and then determine the direction by inspection. That is: F_elec = k*[(|q1||q2|)/r^2] Direction = "you tell me"
| Sep17-09, 08:15 AM | #3 |
Thanks.
The real problem I seem to be having is calculating the answers into a vector form. At first I thought it was simple, and for question 1, divide the unit vector by 2.29059829e-16 (magnitude of grav force) and on the same path, for question 2, divide the unit vector by 1.84615e-7 the electrostatic force between the two objects. This has apparently been disregarded as the correct answer, leaving me with no idea on how to calculate the answers. Would I be correct in assuming the use of the two formulas towards my answer, having r = the values for x and y in the relative position vectors? |
| Sep17-09, 08:33 AM | #4 |
Hmm. I am not sure what the convention is here. We always used the "radial unit vector" to denote the direction. So the answer simply had a magnitude of |F_elec|=k*[(|q1||q2|)/r^2] and a direction of r_hat
If you want to write the answer in Cartesian Coordiantes, then you must take the Magnitude of the Vector: |F_elec|=k*[(|q1||q2|)/r^2] and then multiply it by the unit vector in the direction of r, which is what I think you are trying to say. i.e. r_unit = (rxi+ryj)/|r| |
| Sep17-09, 08:48 AM | #5 |
So.. for problem 2..
1.84615e-7 <-.8320502943, .5547001962, 0> and problem 1, change the scalar to 2.29059829e-16 ? Awsome! it worked. Many thanks saladsamurai. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Gravitational Force Vector exerted by 2 charged objects
| Need help with Charged objects and Electron Force | Introductory Physics Homework | 4 | ||
| Impulse exerted on objects | Introductory Physics Homework | 2 | ||
| How to get the distance from the Sun when the net gravitational force exerted by the | Introductory Physics Homework | 2 | ||
| charged objects and the force between them? | Classical Physics | 2 | ||
| The Gravitational Force (between two spherical objects) | Introductory Physics Homework | 6 | ||
