Simplifying Negative Exponents: How to Add Fractions with Negative Exponents
The problem involves adding fractions with negative exponents, specifically the expression 1/2^10 + 1/2^11 + 1/2^12 + 1/2^12. Participants are exploring how to simplify this expression using properties of exponents.
  • Mixed
  • Some participants discuss converting fractions with negative exponents and consider factoring out common terms. There is confusion regarding the correct exponent to factor out and whether the last two terms are identical.
Participants are actively engaging with the problem, questioning assumptions about exponent rules and discussing different approaches to simplification. Some guidance has been offered regarding factoring and combining like terms, but no consensus has been reached on the correct method or final answer.
There is uncertainty about the correct interpretation of the last term in the expression, and participants are considering the implications of factoring out different exponents. The original poster expresses confusion about their initial approach and the expected answer.
ckolin
1/ 2^10 + 1/ 2^11 + 1/ 2^12 + 1 / 2^12 = ?
i am very confused with this problem as i thought that i would convert the 1/2^X numbers to 2^-X and then add the numbers together. The answer would be 1/2^45. and i know that isn't right. please help!
multiply the whole expression (2^12)/(2^12) = 1
then keep the denominator as 2^12 and simplfy the numerator
You can write this sum as 2-10 + 2-11 + 2-12 + 2-12. (Is the last one supposed to be the same as the third one?)
Now, factor 2-12 out of each term (or 2-13 if the last term is 1/213).
Exponents add when you are multiplying factors, not when you are adding terms, so for example, it is not true that 1/22 + 1/23 = 1/25. Think about it: on the left you have 1/4 + 1/8 = 3/8. On the right, you have 1/32, which is nowhere near 3/8.
Ok i understand that 1/ 2^10 = 2^-10. But with the factoring wouldn't you need to factor out 2^-10? Can you show me the step by step solution. The answer is supposed to be 1/ 2^9
If you were going to factor the expression [tex]x^5 + x^4 + x^2[/tex], what would you factor out? The [tex]x^2[/tex], right? That's because it has the smallest exponent. So for your expression, you want to factor out the power with the smallest exponent, which is -12. You could also factor out [tex]2^{-10}[/tex], just like above you could factor out [tex]x^3[/tex] in my example, but it would leave you with fractions rather than whole numbers.
As an example, if you have [tex]4^{-2} - 4^{-4}[/tex], then our smallest exponent is -4 and we get:
[tex]4^{-2} - 4^{-4} = 4^{-4}[4^{-2-(-4)} - 4^{-4-(-4)}] = 4^{-4}[4^2 - 1] = 4^{-4}[15] = \frac{15}{4^4}[/tex]
The exponent subtraction works exactly the same way.
Actually, looking at this particular problem, there's an easier way to do it.
The last two terms you have are both [tex]\frac{1}{2^{12}}[/tex], so when you add them together, what do you get? What about when that's simplified? Will that work again?
((I'm leaving my other comment about the exponents because it's useful to know, even if it's not necessary for this problem))
