Countability of Algebraic Numbers as Roots of Polynomials
The discussion centers on the countability of algebraic numbers defined as roots of polynomials with integer coefficients. It establishes that for a fixed degree n, the set An of algebraic numbers is countable due to the finite number of roots for each polynomial. By defining Cm as the set of all polynomials whose integer coefficients sum to m, the discussion concludes that An is a union of countable sets, thus countable itself. The argument hinges on the principle that a union of countable sets remains countable.
  • Understanding of algebraic numbers and their definitions
  • Familiarity with polynomial equations and integer coefficients
  • Knowledge of countability in set theory
  • Basic concepts of unions of sets and their properties
  • Study the properties of algebraic numbers in more depth
  • Learn about the implications of countability in set theory
  • Explore polynomial roots and their relationships with coefficients
  • Investigate the concept of finite versus infinite sets in mathematics
Mathematics students, educators, and anyone interested in algebraic structures and set theory, particularly those studying the properties of polynomials and countability.
DPMachine
A real number [tex]x \in R[/tex] is called algebraic if there exist integers [tex]a_{0},a_{1},a_{2}...,a_{n}[/tex], not all zero, such that
[tex]a_{n}x^{n} + a_{n}_{1}x^{n-1} + ... + a_{1}x + a_{0} = 0[/tex]
Said another way, a real number is algebraic if it is the root of a polynomial with integer coefficients...
Fix [tex]n \in N[/tex], and let [tex]A_{n}[/tex] be the algebraic numbers obtained as roots of polynomials with integer coefficients that have degree [tex]n[/tex]. Using the fact that every polynomial has a finite number of roots, show that [tex]A_{n}[/tex] is countable. (For each [tex]m \in M[/tex], consider polynomials [tex]a_{n}x^{n} + a_{n}_{1}x^{n-1} + ... + a_{1}x + a_{0}[/tex] that satisfy [tex]\left|a_{n}\right| + \left|a_{n-1}\right| + ... + \left|a_{1}\right| + \left|a_{0}\right| \leq m[/tex].)
I'm not sure how to explain this coherently... here is what I have. I feel like there are some holes.
-Every polynomial has a finite # of roots (therefore it is countable)
-[tex]m \in N[/tex] is the sum of all integer coefficients for the roots of polynomials.
-Let [tex]C_{m}[/tex] be a set containing all possible polynomials whose integer coefficients add up to [tex]m[/tex] for a fixed [tex]n[/tex]. Since there are finite ways to express [tex]m[/tex] as a sum of integers, each [tex]C_{m}[/tex] is countable.
-Every [tex]A_{n}[/tex] is made up of [tex]C_{m}[/tex], so [tex]A_{n}[/tex] is countable (since union of a countable # of countable sets is countable).
I don't see anything wrong with that. As you said, a union of countable sets is countable. That's the point, right?
Yeah, what I came up with at the end is probably correct... I guess I'm more concerned about whether each step makes sense or if there's anything I should clarify more.
