SUSY computational questions:dots
  • Context: Graduate
  • Thread starter Thread starter haushofer
    Computational Susy
The discussion revolves around computational questions related to supersymmetry (SUSY) as presented in Bilal's notes. Participants explore the properties and manipulations of spinors, particularly focusing on the implications of index contractions, the introduction of inner products, and the significance of signs in equations involving spinors.
  • Some participants explain that spinors are representations of SL(2,C) and that SO(3,1) is locally isomorphic to SU(2)×SU(2), indicating two sectors of spinors.
  • There is a discussion about the inner product between spinors, defined using the epsilon tensor, and how it affects the signs in equations.
  • One participant questions the origin of the negative sign in the identity involving spinors and seeks clarification on index contraction.
  • Another participant emphasizes that the order of index contractions is crucial and that antisymmetric tensors lead to sign changes when swapping indices.
  • There is mention of the need to keep track of conventions used for raising and lowering indices, particularly with the epsilon tensor.
  • Some participants express confusion regarding the treatment of spinors and twistors, especially when multiplying 4-Dirac spinors.
  • References to Srednicki's textbook are made as a resource for further clarification on the topic.
Participants generally agree on the importance of index conventions and the implications of antisymmetry in tensor contractions. However, there remains some confusion and differing interpretations regarding the treatment of spinors versus twistors, as well as the specifics of index manipulation.
Participants note that the discussion involves complex manipulations of indices and the potential for confusion regarding the conventions used. The treatment of spinors and twistors is also highlighted as an area requiring careful consideration.
haushofer
Insights Author
Hi, I'm reading Bilal's notes on SUSY, hep-th/0101055v1, and have some computational questions.
So I understand that spinors can be seen as objects carrying the basis rep. of SL(2,C), and how SO(3,1) is locally isomorphic to SU(2)XSU(2), giving basically two "sectors". With dots and bars we indicate in which SU(2) algebra the specific spinor is sitting.
We can introduce an inner product between spinors via
[tex] \epsilon^{12}=\epsilon^{\dot{1}\dot{2}}=-\epsilon^{21}=-\epsilon^{\dot{2}\dot{1}}=1[/tex]
and an opposite sign for the indices down.
Now, some identities are mentioned, such as (eq.2.15)
[tex] \xi\sigma^{\mu}\bar{\psi} = -\bar{\psi}\bar{\sigma}^{\mu}\xi[/tex]
How can I proof this? What's the origin of that minus-sign? And how do I contract the indices exactly in this equation? I'm a little confused, so to speak :)
The indices look like this:
[tex]\xi^{a}\sigma^{\mu}_{a\dot{b}}\bar{\psi}^{\dot{b}}=-\bar{\psi}^{\dot{b}}\sigma^{\mu}_{a\dot{b}}\xi^{a}=-\bar{\psi}_{\dot{b}}\bar{\sigma}^{\mu}^{\dot{b} a}\xi_{a}[/tex]
The negative sign in the 2nd line comes from swapping two fermion fields which anticommute. In the third line, we lowered and raised some indices with the Levi-Civita an even number of times, so there is no sign change (you can verify that for two spinors, [tex]\psi^a \xi_a=-\psi_a \xi^a[/tex], so you have to be careful if you're swapping indices only once). By definition, [tex]\bar{\sigma}^{\dot{b} a}[/tex] is what you get when you raise the indices of [tex]\sigma_{a \dot{b}}[/tex]
When you write spinors in terms of the indices, you do not have to include "anti-commuting negative signs", this is encoded in the order of the index contractions. Also, it's good practice to rewrite contractions with epsilons. Therefore, according to the conventions in the article, the steps are:
[tex]\chi^{\alpha} \sigma_{\alpha\dot{\alpha}} \bar{\psi}^{\dot{\alpha}} =\bar{\psi}^{\dot{\alpha}} \sigma_{\alpha\dot{\alpha}} \chi^{\alpha} <br /> =-\bar{\psi}^{\dot{\alpha}} \sigma_{\dot{\alpha}\alpha} \chi^{\alpha}<br /> =-\bar{\psi}^{\dot{\alpha}} \epsilon_{\dot{\alpha}\dot{\beta}}\epsilon_{\alpha\beta}\bar{\sigma}^{\dot{\beta}\beta} \chi^{\alpha} <br /> =-\bar{\psi}_{\dot{\beta}}\bar{\sigma}^{\dot{\beta}\beta} \chi_{\beta} [/tex]
This is explained in great detail in the QFT book by Srednicki. You can find a draft copy free at his web page.
You basically state the origin of the sign: indices are contracted through an antisymmetric tensor rather than a symmetric one. Therefore the order of upper and lower indices matter! And it also matters which component you use to lower or raise an index using the epsilon tensor. One has to keep careful track of the conventions you use.
[tex]\chi^\alpha \xi_\alpha = (\chi_\beta \epsilon^{\alpha\beta}) \xi_\alpha = \chi_\beta (\epsilon^{\alpha\beta} \xi_\alpha) = -\chi_\beta (\epsilon^{\beta\alpha} \xi_\alpha) = -\chi_\beta\xi^\beta[/tex]
Here I used the convention for the inner product:
[tex]\chi \cdot \xi \equiv \chi^\alpha\xi_\alpha[/tex]
and the one for raising:
[tex]\xi^\beta= \epsilon^{\beta\alpha} \xi_\alpha[/tex]
This leads automatically to the statement that [tex]\chi \cdot \xi = - \xi \cdot \chi[/tex], which is a bit unconventional if you're just used to ordinary tensor contractions.
Ok, thanks for the answers! So I don't have to introduce minus signs if I swap spinors, but only if I swap indices which concern contractions involving spinors, right?
Let me take the next example:
[tex] (\xi \sigma \bar{\psi})^{\dagger} = \psi\sigma\bar{\xi}[/tex]
So in indices the LHS is, I would say,
[tex] (\xi^a\sigma_{a\dot{b}}\bar{\psi}^{\dot{b}})^{\dagger} = (\bar{\psi}^{\dot{b}})^{\dagger}\sigma^{\dagger}_{a\dot{b}}\xi^{a}^{\dagger}[/tex]
I'm tempted to identify
[tex] (\bar{\psi}^{\dot{b}})^{\dagger} = \psi^b[/tex]
etc, but what happens with the indices of sigma here?
I'll also look at Srednicki, thanks for the tip!
xepma said:
This leads automatically to the statement that [itex]\chi \cdot \xi = - \xi \cdot \chi[/itex], which is a bit unconventional if you're just used to ordinary tensor contractions.
This is true only if your treat [itex]\chi[/itex] and [itex]\xi[/itex] as commuting. If they are anitcommuting, then you have an extra minus sign from the anticommutation, leading to an overall plus sign.
Srednicki explains it.
I ought to mention that the way I did the problem is entirely the way that Srednicki teaches it in his excellent textbook. Obviously there seems to be other ways of doing it and I'm going to have a look at all them because I'm sort of confused now about the difference between twistors and spinors, i.e., once we multiply out 4-Dirac spinors, shouldn't we treat the components as twistors and not spinors?
  • · Replies 24 ·
  • · Replies 16 ·
