How Do You Convert Newtons Per Square Meter to Kilograms Per Square Millimeter?
  • Thread starter Thread starter MalickT
    Newton
The conversion from Newtons per square meter (N/m²) to kilograms per square millimeter (kg/mm²) involves understanding the relationship between these units. Specifically, 1 Newton can be expressed as 1 kg·m/s². To convert N/m² to kg/mm², one must first convert square meters to square millimeters, noting that 1 m² equals 1,000,000 mm². Therefore, the formula G = 0.0135 * 10¹⁰ kg/mm·s² can be derived by applying these conversions correctly.
  • Understanding of unit conversion principles
  • Knowledge of Newton's second law of motion
  • Familiarity with metric system units
  • Basic algebra for manipulating equations
  • Research the derivation of Newton's second law of motion
  • Learn about dimensional analysis in physics
  • Study unit conversion techniques in the metric system
  • Explore practical applications of pressure measurements in engineering
Students in physics, engineers working with pressure measurements, and anyone involved in scientific calculations requiring unit conversions.
MalickT
G = 0,0135*10ˇ10 kg/mm*sˇ2
G = 8,0*Newton*mˇ-2 <- How to transduct this to the one above? (to kg/mm*sˇ2)
You can start by expression 1 Newton in terms of kg, m and s.
Also, you can convert the mm in the first line to m. Then you will have everything in kg, m and s and it should be straightforward (however, I'm not sure about the 8,0).
  • · Replies 18 ·
