How Do You Calculate Current in a Circuit with Multiple Resistors and Batteries?
  • Thread starter Thread starter mattmatt321
    Circuit Loop
The discussion focuses on calculating current in a circuit with multiple resistors and batteries, specifically using a circuit with all resistances at 4 ohms and ideal batteries with an emf of 12.4 V. The participant initially attempted to apply a single loop equation but realized the complexity of the circuit required a more comprehensive approach. Key insights include the necessity of simplifying the circuit by identifying parallel and series resistances and recognizing points of equal potential. Ultimately, a single loop can be established by isolating the relevant resistors and voltage sources.
  • Understanding of Ohm's Law and Kirchhoff's Laws
  • Familiarity with series and parallel resistor configurations
  • Knowledge of ideal voltage sources and their behavior in circuits
  • Ability to analyze circuit diagrams and identify equivalent circuits
  • Study the application of Kirchhoff's Voltage Law in complex circuits
  • Learn how to simplify circuits using Thevenin's and Norton's Theorems
  • Explore techniques for analyzing circuits with multiple loops and nodes
  • Practice solving problems involving ideal and non-ideal voltage sources
Students studying electrical engineering, circuit designers, and anyone looking to enhance their understanding of current calculations in complex resistor networks.
mattmatt321
What is the magnitude i in the figure below, if all resistances are 4 ohms, and all batteries are ideal with an emf of 12.4 V?
http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c27/pict_27_70.gif
I realize I need to set up a loop equation. I decided to start in the lower left hand corner, turn left at the first "branch", go through the parallel resistors, through the unknown current, then turn left again, through the resistor, then left again, through the battery, and back to my starting point. I realize this completely disregards the rest of the circuit, but I do need a simple loop equation because as soon as I incorporate additional currents, I have too many unknowns and it can't be solved. My answer of 0.886 A through the given resistor is incorrect, and I have checked my loop equation multiple times.
The picture looks daunting, but I feel like it's very do-able; I just need a loop that will work. Can anyone point me in the right direction?
A single loop equation is no use. You don't know if the same current is going through all the resistances in the loop. You need to replace all parallel and series resistances you can find. Some of the points of the circuit can be shown to have the same potential. For example the top left and bottom left corners. You can connect those with a wire.
If you ever get 2 of the voltage sources in parallel, you can replace them with a single voltage source of the same voltage if plus is connected to plus and minus to minus.
If they short each other something must have gone wrong.
It turns out that there is indeed a single loop that you can use. If your loop only follows wires and voltage sources, except for the chain of 4 resistors on the bottom left, than you can work out the voltage across those resistors, because the voltage sources always have 12.4 V across them, no matter what.
make a copy of the image, and erase all of the resistors, except for the 4 in the bottom left corner. you'll have one loop left.
  • · Replies 48 ·
