Proving Rational Intersection of Sets with Irrational Elements
  • Thread starter Thread starter KeynesianDude
    Rational Sets
The discussion revolves around proving that the intersection of two sets, S and T, defined with elements involving square roots of irrational numbers, results in the set of rational numbers. The sets are S={p+q√2 : p,q ∈ Q} and T={p+q√3 : p,q ∈ Q}.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the equality of elements from both sets and question under what conditions the intersection can be rational. Some suggest considering specific cases where coefficients are zero, while others discuss rearranging the equations to analyze rationality.
Participants are actively engaging with the problem, suggesting various approaches to demonstrate that both q and t must equal zero for the intersection to hold. There is a recognition of the need to consider multiple cases, and some guidance has been offered regarding the implications of squaring both sides of the equations.
There is an emphasis on the necessity of showing that certain conditions must be met for the intersection to be rational, and participants are encouraged to explore these conditions without reaching a definitive conclusion.
KeynesianDude
Let S={p+q[tex]\sqrt{2}[/tex] : p,q [tex]\in[/tex] Q} and T={p+q[tex]\sqrt{3}[/tex] : p,q [tex]\in[/tex] Q}. Prove that S[tex]\cap[/tex]T = Q.
See above.
I was thinking possible using
S[tex]\cap[/tex]T=Q
S + T - S[tex]\cup[/tex]T = Q
But I have no idea how to combine them? I don't believe it's necessary to first prove S and T are rational individually.
hmmm... not sure but is there some way to show that
[tex]p + q\sqrt{2} = s + t\sqrt{3}[/tex]
iff q=t=0
(maybe consider the case p = s = 0 first)
then the intersection reduces to only the rationals?
Thanks for your response. I was thinking the same thing.
Would it be a bad idea to transfer this to one of the math discussion threads? It's high-level undergrad and low-level grad type proof writing class.
why not try it first... (more volume here & they're not meant for homework)
say you have
[tex]p + q\sqrt{2} \in Q}[/tex]
[tex]s + t\sqrt{3} \in T}[/tex]
the intersection will be given by elements that satisfy
re-arranging
[tex]p-s = (t\sqrt{3} -q\sqrt{2})[/tex]
the left is cleary rational, can the righthand side ever be rational? (haven't tried to prove it or find conditions, but probably a good place to start)
lanedance said:
why not try it first... (more voluem here & they're not meant for homework)
say you have
re-arranging
You should probably try and solve it before you transfer it. lanedance has good suggestions. Square both sides if t and q are both nonzero. Is sqrt(6) rational? Or is sqrt(2) or sqrt(3) if one of t or q happen to be zero?
[[tex]\sqrt{6}[/tex] is definitely not rational. I squared both sides and am kind of clueless. It seems like no matter what I do it will always come off as irrational.
It seems like I need to get t or q to be zero to this to work, huh?
You want to prove t AND q are both zero. You've got three cases to worry about. t=0, q not zero, q=0, t not zero and q and t both not zero. Yes, you need t=q=0 to make it work. Can you show this?
Would this be acceptable?
Suppose 3t2-2[tex]\sqrt{6}[/tex]tq+3q is rational, then q:=0. Hence,
(p-s)2=3t2
Both sides are clearly rational. Therefore, S[tex]\cap[/tex]T [tex]\in[/tex] Q.
helps if you show what you are doing, but i think that's the plan
Remember this is the equation that must be sastified by any points in the intersection of S & T.
so note if u is rational, then so is u^2. So as you're hinting... what limits can you put on t & q, to be in the intersection? will need to consider all the cases as Dick mentioned
(p-s)2=3t2
no - consider the case separately when t,q both non zero, then look at the square
if one of t,q = 0, there is no need to look at the square
note that sqrt(2) is not rational but (sqrt(2))^2 is not,
i think this is because you can show that u^2 irrational implies u is irrational, but u irrational does not imply u^2 is irrational
