| Thread Closed |
Difference between mechanical switch and a transistor switch? |
Share Thread | Thread Tools |
| Oct17-09, 02:16 PM | #1 |
Doesn't a transistor switch need a mechanical switch? Otherwise, how does the transistor switch turn on and off? Does the switch have a "mind" of it's own?
| Oct17-09, 03:44 PM | #2 |
A transistor switch, e.g., an npn transistor, can be triggered by a sound, light (photodetector), an electrical signal, or a radio signal (e.g., garage door opener).
Bob S |
| Oct17-09, 04:19 PM | #3 |
| Oct17-09, 04:36 PM | #4 |
I believe the answer to your last question can be readily found by considering the NMOS or PMOS transistor.
| Oct17-09, 07:58 PM | #5 |
Recognitions:
Bipolar junction transistors draw very little collector current if they have no base current and draw a lot more current if they do have a base current. So, to make them draw collector current you just need to produce a base current from some event. If the event is very short (in time) then there are ways of producing a much longer time to turn a switch on or off for a longer time. If they do draw a collector current, this can be used to do something useful. You might turn on a LED, for example. The transistor has to be used in certain ways to keep it safe and so it works at all, so it is not as easy to use as a mechanical switch but it has many advantages. It can be triggered by electrical signals. It can switch much faster than a mechanical switch. It is silent. It never wears out. A good example.. Suppose you want to turn on a light when the sun goes down. You have a light detector driving a transistor switch which turns on the light. It isn't as simple as that, but you get the idea. How would you do that with a mechanical switch? |
| Oct17-09, 10:01 PM | #6 |
I use it to turn on a 120 Vac lamp for 4 hours after sunset every day. Very convenient. Bob S |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Difference between mechanical switch and a transistor switch?
| about Using transistor BJT as a switch | Electrical Engineering | 9 | ||
| Transistor as a switch | Electrical Engineering | 17 | ||
| transistor as a switch | Electrical Engineering | 6 | ||
| Transistor As Switch | Introductory Physics Homework | 5 | ||
| BJT transistor as a switch | Electrical Engineering | 21 | ||
