Faraday's Electrolysis Forumlae question
  • Thread starter Thread starter philip_pc
    Electrolysis
The discussion revolves around the application of Faraday's electrolysis formula in a practical assessment involving the electroplating of a 20 cent coin with copper. Participants explore the theoretical calculations needed to determine the amount of copper that can be plated out, including the relationship between moles of electrons and moles of copper ions.
  • Homework-related
  • One participant expresses confusion about using Faraday's formula to calculate the theoretical amount of copper plated, questioning the relationship between electrons and copper ions.
  • Another participant clarifies that the formula can be used to find the moles of electrons, which can then be related to moles of copper using stoichiometric ratios.
  • A third participant explains the electrochemical reaction involved, emphasizing the need for copper ions and the stoichiometric relationship of 2 moles of electrons for every mole of copper deposited.
  • Further clarification is provided on how to convert the charge from the current and time into moles of copper by applying the molar mass of copper.
  • One participant seeks confirmation on their understanding of the calculations, specifically the conversion of moles of electrons to moles of copper.
  • Another participant reiterates the steps needed to calculate the mass of copper deposited based on the charge and the stoichiometric relationships.
Participants generally agree on the application of Faraday's formula and the stoichiometric relationships involved, but there is some initial confusion regarding the calculations and the interpretation of the relationships between electrons and copper ions.
Some participants express uncertainty about the specific details of the problem, such as the initial mass of the coin and the exact parameters of the electroplating process, which may affect the calculations.
Students and educators involved in practical assessments related to electrochemistry, particularly those focusing on electrolysis and electroplating techniques.
philip_pc
i have a practical assesment i need to complete at school and i come across this problem...i am to electroplate a 20 cent coin with a layer copper, i have all the experiment setup but I'm a bit confused abit about the faraday formula...
one of the calculations i need to work out is the THEORETICAL amount of copper that is plated out...
do i work out this answer via the faraday formula?, cause i am confused...
faraday's formula is [no. moles electrons = (current x time)/96500)]...correct me if I'm wrong...
i cannot see how i can work out the theoretical amount that should be plated out from the copper :confused: ...please help me. It only talks about the amount of electrons...or does it have something to do with Cu --> Cu2+ + 2e-
please help me out here, because this assesment is due soon, and i need to have it all clear (not a open book thing)lol :smile: ...
Chemistry news on Phys.org
well, current x time will give you charge, charge over Faraday's Constant will give you moles of e-, but anyway, that's what you have up there
yes, you could work it that way IF they give you the mass you need to plate the coin successfully, OR you could go through a bunch of rigmarole to look up the unit cell dimensions of copper, then figure out how many moles would give you at least a monolayer or two, and so on, but I doubt the problem is that involved
did they give you "the coin starts off this many grams and after plating should weigh that many grams?" If so:
Just use the formula to figure out how many moles of electrons would have to pass to reduce x moles of Cu(II) ( 2 times x ) and that's it (besides converting back to grams if you need to).
Well if you have to electroplate with copper, you will have to use something like copper sulfate and deposit copper on the coin starting from copper ions. You need (solvated) copper ions for this and so, the equation
[tex] Cu^{++}(aq) + 2e^{-} -> Cu(s)[/tex]
represents in totality what you need to do. From this, you see that you need "2 moles of electrons" (thats how these sums work and it seems odd at first sight) to effect the process of depositing 1 mole of copper from 1 mole of copper ions. So, you need 96480C times 2, or 96500C times 2(whatever you prefer) to do this. But let us say that you have a current source that gives out a (constant) current of I amperes.
So in time t, it will give a charge equal to I*t coulombs. So the amount of copper (in moles) deposited through this source in a time of t seconds is given by
[tex] \frac{1}{(2 * 96500) C} * [ (I*t) C ] moles[/tex]
You can convert this to mass by multiplying with the molecular weight of copper. That should see you through I think.
Hope that helps.
but according to what ur saying...if i do it that way, it only gives me the number of moles of electrons. how to i find the mass of copper using the number of moles of electrons given.
i can't see the relationship between the copper and the electrons.
or maybe I'm a bit dud i i don't understanding what your trying to tell me...lol :)
is it possible for you to explain to me a bit clearer...sorry about it
wait wait wait...what your trying to say is that i need to work out the number of moles of electrons required. because the copper to electron ratio is a 1:2 ratio, i just divide the no. of moles of electrons by 2 and that gives me the no. of moles of copper and i get the mass from there, by timesing by the molar mass of Cu...
is this right, or have i got the wrong interpretation?
What do you mean by "timesing"? I am sorry, but I mean multiply by the molar mass. Here's the list of steps...
1. First write the equation for the electrochemical process.
2. Next identify the stoichiometric coefficients of the relevant species. In our case, we need 2 moles of electrons to deposit one mole of copper given one mole of copper (cuprous) ions.
NOTE: 1 mole of electrons corresponds to a coulomb charge of 96500 C or 96480 C.
3. Now, use the unitary method or ratios, whatever you're comfortable with. Its somewhat like this:
2 * 96500 C of charge is required to deposit 1 mole of Cu.
x C of charge will deposit [tex]\frac{1 mole}{2*96500C}*xC = \frac{x}{2*96500}[/tex] mole or moles of Cu.
4. Now multiply this with the molar mass of copper (63.54 g/mole) to get the mass of copper deposited.
Hope that helps...
Vivek
To add to what I said sometime back, x is simply the charge that your current source gives in a time interval t. So if the current source is a constant current source rated at I amperes and the time for which the process is conducted is t seconds, then x = I * t coulombs. Equate this to the ratio for x, so the mass deposited in terms of I and t is given by the equation
[tex] mass = \frac{I * t}{2*96500}*63.54 g[/tex]
OH OK i got it now...
all clear now...after i saw that last equationi got it.
its A.L.L clear now
thanks a million maverick280857
Regards,
Philip
  • · Replies 19 ·
13K
