| Thread Closed |
Cosine and Sine rules to get magnitude and direction of a resultant force |
Share Thread | Thread Tools |
| Oct20-09, 06:52 PM | #1 |
Use the cosine and sine rules to determine the magnitude and direction of the resultant of a force of 11 kN acting at an angle of 50 degrees to the horizontal and a force of 6 kN acting at an angle of -30 degrees to the horizontal.
helppp please |
| Oct20-09, 06:57 PM | #2 |
What have you tried doing? Have you drawn a diagram of the situation -- Will make things much easier.
| Oct20-09, 06:59 PM | #3 |
No i haven't.
Do you know how to find resultant forces with forces and angles from axises? because I have another problem like that and i have no idea how to do them |
| Oct20-09, 07:27 PM | #4 |
Well maybe draw one then
At least then you actually have a triangle to apply the cosine and sine rules to. If you are given forces and angles relative to axes, you could again do the same thing and form a triangle to be solved with geometry, or perhaps easier would be to resolve each force into a horizontal and vertical component and add the components. |
| Oct9-10, 06:38 AM | #5 |
Hi All
to get magnitude of resultant use cosin rule R^2= X^2+Y^2 – 2XYcosβ to get the direction use sine rule = (Sin β /length of opposite line) = (sinθ/ length of opposite line) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Cosine and Sine rules to get magnitude and direction of a resultant force
| Finding the Magnitude and Direction of Force one with the Resultant Given | Introductory Physics Homework | 15 | ||
| calculate the magnitude, direction and sense of the resultant force | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Finding magnitude and direction of resultant force | Introductory Physics Homework | 5 | ||
| Magnitude and Direction ofeach resultant for the giiven vectors. | Introductory Physics Homework | 0 | ||
| Magnitude and direction of the resultant. | Introductory Physics Homework | 1 | ||
