| Thread Closed |
Age vs. Size of universe. |
Share Thread | Thread Tools |
| Oct22-09, 07:55 PM | #1 |
Hi all,
This is my first endeavor into the astronomy forum. I have a question, regarding three things I think I know about the universe. 1. the universe started as a singularity. 2. it has expanded to 78 billion light-years across. 3. it did that in only 13.7 billion years. How did it do that without things moving faster than the speed of light, relative to other things? I'm sure someone has answered this Q before, but I couldn't find anything. Feel free to direct me to another thread instead of answering this Q again. |
| Oct22-09, 08:09 PM | #2 |
Special Relativity prohibits objects moving through space faster than c. It does not prohibit space expanding faster than c.
| Oct22-09, 08:14 PM | #3 |
So, relative to space, the galaxies aren't moving faster than c, but are they moving faster than c relative to us?
| Oct22-09, 08:19 PM | #4 |
Age vs. Size of universe.Galaxies distant from us are receding - due to the expansion of space - faster than c. |
| Oct22-09, 10:58 PM | #5 |
So, since light moves through space at a constant velocity c, regardless of the velocities of the source or the observer, then once a galaxy is receding faster than c, relative to us, it should "disappear", right?
If that's the case then "curtain" around us, outside of which no emitted electro magnetic radiation will ever reach us, right? |
| Oct22-09, 11:24 PM | #6 |
It is called "the observable uiniverse" and it forms the boundary of what science will address. You are remarkably clever. I hope you are making good use of it. |
| Oct22-09, 11:42 PM | #7 |
This is where time dilation comes into play. We routinely observe galaxies that were receding faster than c when photons now reaching us were emitted. They just take longer to reach us. As space stretches, it also stretches the wavelength of light passing through it, resulting in redshift - aka known as time dilation.
| Oct23-09, 02:37 AM | #8 |
Recognitions:
Note that the notion of 'space expanding' is inherently co-ordinate dependant, that is to say, it is not a physical process or physical law, but a notion that has relevance for a particular (and very usefull) co-ordinate system. Nothing anyone has said here is incorrect, but the statements are correct only from a certain point of view (albeit a very usefull point of view). Just be cautious about thinking too literally about the expansion of space being a physical or causative process.
A consuquence of the important property of general covariance that GR obeys is that you cannot uniquely describe what 'space' does, you can only unambigously talk about space-time, and even then the theory forbids the specification of any unique set of co-ordinates. |
| Oct23-09, 10:23 AM | #9 |
| Oct23-09, 10:36 AM | #10 |
Recognitions:
Well, for instance, if you transform the usual FRW metric into a form that is a conformally related to the Minkowski metric then you have a model in which everything (say all galaxies) are moving away from wherever your chosen origin is, and all redshifts can be thought of as being purely doppler shifts due to the relative velocities. There is no 'expanding space' in such a model, yet it describes the exact same underlying physical system as the FRW metric. Remember that velocity is the change in distance divided by the change in time. Since neither distances or times are unique in GR (they depend on how you've defined your co-ordinates) the 'velocity' of a distant galaxy actually has no unambigous meaning. That's why you can choose a co-ordinate system in which the co-ordinates themselves encode all the physics that gives you the redshift. Incidentaly this is also why no one need get their knickers in a knot about galaxies recceeding faster than light. It it purely to do with how velocities are defined in the FRW system. In the conformal metric, there are no super-luminal velocities. Just by chaning co-ordinates we have apparently turned super-luminal motion into sub-luminal motion! The lesson is that co-ordinate velocities shouldn't be compared with c in that way. There never was super-luminal motion that needed to be explained away by an ill defined notion such as 'space can expand at faster than c'.
I don't suggest that such a metric is more usefull than the FRW one we use, far from it! I just point out that there is no physical basis for expanding space that appears when you use the FRW system. That's not to say it is an unhelpful concept, but just one that needs to be treated with caution. The idea that galaxies are at rest in an expanding background has a lot of utility, you just have to always keep in mind that this is just one particularly useful co-ordinate description, rather than being physically true in an unambigous way. By all means continue think about the expanding universe in this way, and explaining it to others in this way, just remember though that you are explaining something that is at best a metaphor. |
| Oct23-09, 10:48 AM | #11 |
Rather than space expanding, it could be time contracting? |
| Oct23-09, 11:01 AM | #12 |
Recognitions:
So when you say 'Rather than space expanding, it could be time contracting?', you first have to understand what the 'it' you speak of is referring to? If by 'it' you mean 'the cause of cosmological redshift' then neither answer is wrong or right, it depends on the co-ordinates you use. There is no mystery, paradox or problem with this, it's just a consuqence of general co-variance. |
| Nov5-09, 08:37 AM | #13 |
Anyway, I had a couple more questions about relativity. I hope they don't make you revoke your comment :) 1. Shouldn't we be able to look back at earlier stages of the universe, but see them very very red-shifted? Maybe as radio waves, by this point? What is the lowest frequency wave we can detect without interference? How long ago would that represent? We'd obviously do any detection from outside our atmosphere. 2. I understand how we detect the expansion of the universe, but how do we quantify it? 3. As galaxies are separated, aren't their gravitational potential energies increasing? If so, that energy would have to come from somewhere, so wouldn't that put a cap on how big the universe can get? Wouldn't a forever-expanding universe be impossible? |
| Nov5-09, 09:02 AM | #14 |
Recognitions:
The limit for looking back is the point where matter/photons decoupled (essentially the universe became large and cool enough that matter ha a chance of staying around and not being immediately annihilated). This is the microwave background an has been redshifted from it's initial extremely high energy to microwaves at 2.7Kelvin |
| Nov6-09, 02:23 AM | #15 |
The observational limit on the universe is, and will always be, the CMB - about 2.7 degrees kelvin. You can convert this to a radio frequency of around 0.3 cm according to current measurements. The temperature at the time of emission is estimated at about 3000 kelvin. Note that if you divide the estimated emission temperature by the current measured temperature you get about 1100 - which is the redshift of the CMB.
| Nov23-09, 09:12 AM | #16 |
http://www.youtube.com/watch?v=7ImvlS8PLIo where he claims that the total energy in the universe is zero. He also claims that this zero total energy is what allows the universe to begin from nothing, and also (if I recall correctly) associates that fact with a flat universe. Are Krauss' views out of the mainstream? |
| Nov23-09, 01:29 PM | #17 |
I watched that talk "universe from nothing" and found it very entertaining. He is a wonderful public speaker. He oversimplified radically. He also left out qualifiers and reservations like "possibly" or "perhaps" or "some cosmologists conjecture that". It was a fun talk. I would not take any statement in the talk too seriously. I think Krauss' views (as a scientists talking to scientists) are not out of the mainstream at all! He is highly respected, he gets invited to give talks at major conferences. His papers are highly cited. etc. He would not (except in a talk like that Youtube) suggest that we know that the universe is exactly flat. However there is good evidence that it is "nearly" flat. There is an errorbar. Within one or two percent, as I recall. It keeps narrowing down as more data is collected. The total energy of the universe has not yet been rigorously defined. One cannot say that it is zero. However it is a neat speculation that it might be zero. It could be. Also "from nothing" sweeps a lot of conjectural detail and unstated assumptions under the rug. If actually from "nothing" then a very special definite kind of "nothing" and different people have different mathematical models for it. And "nothing" only as a manner of speaking when one talks to a lay audience. Stephen Hawking used to give these kinds of riffs and write that kind of books. I actually like Krauss doing it a lot more. He is fundamentally more honest and less self-deluded. But however you slice it cosmology-as-entertainment introduces a drastic distortion. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Age vs. Size of universe.
| Size of the Universe | Astrophysics | 14 | ||
| The Size of the Universe | Cosmology | 13 | ||
| Size of Universe | Cosmology | 11 | ||
| The size of the universe | Cosmology | 7 | ||
| Size and age of universe | General Astronomy | 28 | ||
