Evaluating Logarithms: Solving 2^x - 2^{1-x} = 1 in Simple Steps
  • Thread starter Thread starter Matty R
    Logarithms
The discussion revolves around evaluating the equation 2^x - 2^{1-x} = 1, which involves logarithmic concepts. Participants express confusion regarding the application of logarithmic properties and seek clarification on the correct approach to solve the equation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Some participants attempt to apply logarithmic properties to simplify the equation, while others question the validity of these steps. There is a suggestion to rewrite the equation in a different form to identify a quadratic relationship.
Participants are actively engaging with the problem, sharing their attempts and questioning the methods used. Some guidance has been offered regarding the limitations of logarithmic properties in this context, and alternative approaches are being explored.
There is a noted confusion regarding the properties of logarithms, particularly in relation to the subtraction of terms. Participants are also reflecting on their prior experiences with logarithmic problems, which may influence their current understanding.
Matty R
Hello
I was wondering if someone could help me.
I've got a question on evaluating logarithms, but I've not done anything like this before. I'm only used to the basic logarithmic stuff, and I still find that a bit confusing.
So, I've been trying to do this question for hours now, and keep getting x=1/2, x = -2 or 1 = 1, despite knowing that x = 1
Could anyone shed some light on this for me? I'm so confused.
Thank you
[tex]Evaluate : 2^x - 2^{1-x} = 1[/tex]
[tex]logb^n = nlogb[/tex]
[tex]2^x - 2^{1-x} = 1[/tex]
[tex]log(2^x) - log(2^{1-x}) = log(1)[/tex]
[tex]xlog(2) - (1-x)log(2) = 0[/tex]
[tex]log(2)(x - (1-x)) = 0[/tex]
[tex]log(2)(2x-1) = 0[/tex]
[tex]2xlog(2) - 1log(2) = 0[/tex]
[tex]2xlog(2) = log(2)[/tex]
[tex]2x = \frac{log(2)}{log(2)}[/tex]
[tex]2x = 1[/tex]
[tex]x = \frac{1}{2}[/tex]
If you take log on both sides, you get [tex]log(2^x - 2^{1-x})[/tex] on the LHS, which is not equal to [tex]log(2^x) - log(2^{1-x})[/tex].
The method to solve it is not by logarithms; try simplifying the expression to see if you can see the underlying equation present.
Matty R said:
Hello
Thank you
Your next step is wrong. You can take the log of each side of an equation, but there is no property that says log(a - b) = log a - log b. That is what you've done, and it is invalid.
Rewrite your equation as 2x - 2/2x = 1, and then multiply both sides by 2x. That should give you an equation that is quadratic in form (in powers of 2x) that you can solve.
[tex]2x = 1[/tex]
Thanks for the replies. :smile:
I'd been doing questions with logarithms just before I got to this question, so when I saw the power of x I thought of logarithms and nothing else.
Sooooo, how about this?
[tex]2^x - 2^1 \cdot 2^{-x} = 1[/tex]
[tex]2^x - \frac{2^1}{2^x} = 1[/tex]
[tex]2^x - \frac{2}{2^x} - 1= 0[/tex]
[tex]y = 2^x[/tex]
[tex]y - \frac{2}{y} - 1 = 0[/tex]
[tex]y^2 - 2 - y = 0[/tex]
[tex]y^2 - y - 2 = 0[/tex]
[tex]y^2 - 2y + 1y - 2 = 0[/tex]
[tex]y(y - 2) + 1(y - 2) = 0[/tex]
[tex](y - 2)(y + 1) = 0[/tex]
[tex]y = 2[/tex] and [tex]-1[/tex]
[tex]y = -1[/tex]
[tex]2^x \neq -1[/tex] ([tex]2^x[/tex] cannot be negative)
[tex]y = 2[/tex]
[tex]2^x = 2[/tex]
[tex]log(2^x) = log(2)[/tex]
[tex]xlog(2) = log(2)[/tex]
[tex]x = \frac{log(2)}{log(2)}[/tex]
[tex]x = 1[/tex]
  • · Replies 24 ·
