How Do You Solve for Coefficients in a Power Series for a 2nd Order DE?
The discussion focuses on solving for coefficients in a power series for a second-order differential equation (DE) using initial conditions. The initial conditions provided are y(0) = 1, leading to a_0 = 1, and y'(0) = 0, resulting in a_1 = 0. The expressions derived from the power series are 2a_{2}+2a_{1}+a_{-1}=0, 6a_3+6a_2+a_0=0, and 24a_4+12a_3+a_1=0. It is clarified that a_{-1} does not equal x, as it represents a coefficient for x^-1, which is not included in the power series.
  • Understanding of second-order differential equations
  • Familiarity with power series expansions
  • Knowledge of initial conditions in differential equations
  • Ability to manipulate algebraic expressions and solve for coefficients
  • Study the method of power series solutions for differential equations
  • Learn about initial value problems in differential equations
  • Explore techniques for solving recurrence relations
  • Investigate the implications of negative subscript coefficients in series solutions
Students and professionals in mathematics, particularly those focusing on differential equations, as well as educators teaching advanced calculus or mathematical analysis.
bhajee
After setting out in the sums and collecting the terms in [tex]x^j[/tex] I'm left with a series of expressions in
[tex]a_2, a_3[/tex] etc as I believe I'm supposed to. However my first expression reads
[tex]2a_{2}+2a_{1}+a_-_{1}=0[/tex]
Now I'm told that
[tex]y(o) = 1[/tex] and
[tex]y'(o) = 0[/tex]
I think this means that
[tex]a_0 = 1[/tex]
and
[tex]a_1 = 0[/tex]
does this mean that
[tex]a_-_1 = x[/tex]?
(My other expressions are
[tex]6a_3+6a_2+a_0=0[/tex]
and
[tex]24a_4+12a_3+a_1=0[/tex])
i'm always left with an
[tex]a_-_1[/tex]
when finding the other
[tex]a_{j}[/tex]'s
usually, negative subscript coefficients are set equal to zero initially in series solutions for differential equations.
It is correct that after setting up the power series and collecting terms in x^j, you will be left with a series of expressions in a_j. In order to solve for the coefficients a_j, you will need to use the initial conditions y(0) = 1 and y'(0) = 0. These conditions will give you the values for a_0 and a_1, as you have correctly stated.
However, it is not correct to say that a_-1 = x. The subscript j in a_j represents the power of x, so a_-1 would mean a coefficient for x^-1, which is not present in the power series. Instead, you will need to use the equations you have listed (2a_2+2a_1+a_-1=0, 6a_3+6a_2+a_0=0, and 24a_4+12a_3+a_1=0) to solve for the remaining coefficients.
For example, to solve for a_2, you can substitute in the values a_0 = 1 and a_1 = 0 into the first equation, and then solve for a_2. Similarly, you can use the second equation to solve for a_3 and the third equation to solve for a_4. This process can be continued for higher values of j to find the remaining coefficients.
So while a_-1 is not equal to x, it is still an important coefficient that needs to be solved for in order to find the solution to the second order differential equation using the power series method.
