| Thread Closed |
sound output on ibm laptop not working |
Share Thread | Thread Tools |
| Oct26-09, 11:40 AM | #1 |
I had this problem before. But a friend of mind open up my laptop and fixed it. I was told that I could also reinstall sound drive for laptop , but don't know the procedures for reinstalling sound driver. I have already checked that whether the sound was muted , turns out it was not muted. What option should I take into consideration for reviving the sound on my laptop?
| Oct26-09, 09:36 PM | #2 |
please help me
| Oct26-09, 10:11 PM | #3 |
Mentor
If you see a speaker icon next to your clock, chances are you have your sound drivers properly installed. Double click the icon and make sure all the sound levels are above zero.
| Oct26-09, 10:21 PM | #4 |
| Oct27-09, 09:05 AM | #5 |
What OS are you running? If you are running Windows then open the command prompt. (I think it was called "Run" in the start menu of Windows XP) and type:
Code:
dxdiag If you're using Linux then please tell us what distro you're running and I'll help from there. It could just be that your sound card copped it though, maybe a wire broke or came loose? If you're running Windows you could use a live linux distribution and see if your sound works from there. (I'll suggest Linux Mint or Ubuntu). |
| Oct27-09, 05:24 PM | #6 |
Did any of the suggestions on your other thread work?
| Oct27-09, 07:06 PM | #7 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: sound output on ibm laptop not working
| Convert Digital Output from DAQ to Analog output? | Electrical Engineering | 4 | ||
| Interference on sound and monitor when I plug my laptop in to charge. | Computing & Technology | 4 | ||
| Java project output problem. Can't output objects from a method. | Engineering, Comp Sci, & Technology Homework | 0 | ||
| can u make "if A>=B then output=1 Else output=0" using these logic gates? | Advanced Physics Homework | 7 | ||
| how to get output voltage from the tachometer output | Engineering Systems & Design | 1 | ||
