Gauss law, having problem with spherical load distribution, me
The discussion revolves around a problem involving Gauss's law and a spherically distributed charge density. The charge density, ρ, is defined piecewise based on the distance from the center of the distribution, with specific equations for different regions. Participants are tasked with determining the constant a in terms of the total charge Q and the radius R, as well as finding the electric field in different regions using Gauss's law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the relationship between charge density and total charge, questioning how to express the constant a based on the given equations. There are attempts to apply Gauss's law to find the electric field in different regions, with some participants expressing uncertainty about the correct approach and the implications of the piecewise definition of ρ.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided guidance on using charge density and volume integrals, while others are still grappling with the concepts and calculations involved. There is no explicit consensus on the correct approach or solution yet.
Participants note the complexity of the problem due to the non-uniform charge distribution and the requirement to integrate over different regions. There are mentions of the need for a deeper understanding of calculus and spherical coordinates to fully grasp the problem.
kliker
A region in space containing cargo which is distributed spherically so that the stocking load ρ is given by the equotations:
ρ = a for r<=R/2
ρ = 2a(1-r/R) for R/2<=r<=R
ρ=0 for r>=R
The total charge Q is 3*10^-17 C, the radius R of the overall distribution is 2*10^-14 m and a is a constant which has dimensions of C / m^3. Determine the constant a as
function of Q and R and the numerical value. b) Using the
Gauss's law find an expression for the measure of the electric field as a function of distance r
from the center of distribution. Do this separately for each of the three areas.
Make sure that your results agree with the borders of the areas. What fraction of
total load is contained within the region r<R/2?i spent like 3 hours to solve this, but no success
ρ = a for r<=R/2
ρ=0 for r>=R
How is charge density, [tex]\rho[/tex], related to total charge [tex]Q[/tex] for a spherical charge? If you can find that relation, the first part is solved by inserting your values of [tex]\rho[/tex] in that relation.
What is Gauss's Law? More accurately, what is the equation for Gauss's Law? If you know the equation, you should be able to insert the charge density into this and find the answer.
thanks for the answer
i know that ρ = Q/(4/3pir^3) right?
if i take r as R/2 and find ρ, how can i find a? i mean for R/2 we have two different equotations, then
if i take a gausian surface the Qencl would be Qencl = ρ * V where V = 4/3pir^3 then E would be E = Qencl/eo*Qencl
i really think it's something like this but I am not 100% sure
ps: this is from the book "university physics by d young"
You have three areas where the charge density exists:
[tex] \rho=\left[\begin{array}{ll}a &\,\,\,\,\,r<\frac{R}{2} \\ a\left(1-\frac{r}{R}\right)&\,\,\,\,\,\frac{R}{2}\leq r\leq R \\ 0&\,\,\,\,\,r>R\end{array}\right.[/tex]
I would solve the middle one for [tex]a[/tex] in terms of [tex]\rho[/tex]:
[tex] \rho=a\left(1-\frac{r}{R}\right)\rightarrow a=\frac{\rho}{1-\frac{r}{R}}[/tex]
Then replace [tex]\rho[/tex] with your total charge that you have above. The electric field equation you have is wrong, you should have:
[tex] E_r=\frac{\rho}{\varepsilon_0}=\frac{Q_{enc}}{V\varepsilon_0}[/tex]
thank you again, this is actually what i did before, the answer in the book for a question is a = 8Q/5piR^3
but i keep finding a = 6Q/piR^3
Why would you do that? :confused:
hello, gabbagabbahey, what would you do in this case? I'm really stuck, this is like the last exercise i need to solve in order to finish my assignment
thanks in advance
No, that is only when the charge is uniformly distributed over a sphere of radius 'r'...More generally, the volume charge density is defined according to the equation [itex]dq=\rho dV[/itex], where [itex]dq[/itex] is the amount of charge located in the infinitesimal volume element [itex]dV[/itex]...to get the total charge of any distribution, you need to integrate over all space (or at least a volume that encloses the entire charge distribution):
[tex]Q=\int_{\text{all space}}\rho(\textbf{r})dV[/tex]
can you explain me what ρ(r) and "all space" are?
from the integral i found that Qw = Q*ln(V) where V = 4/3pir^3
Haven't you encountered volume integrals before? Have you taken 2nd year calculus?
no i don't think so, I am studying computer science 1 year, sorry for my bad english I'm from russia
You really need to have taken a multivariable calculus course to understand electrodynamics...what course is this problem for, and what textbook are you studying from? Are you familiar with spherical coordinates?
it's for physics, this exercise (23.27) is from the book university physics by Hugh D. Young
where can i find these courses? i really need to understand and solve this by tomorrow
Thanks
That text has a few examples of volume integrals in spherical coordinates, I suggest you look at them.
thank you for the answers, i ve studied everything in there
after some time i found this AWESOME guy http://www.youtube.com/watch?v=nvq_4OFp_IE&NR=1
explaining different examples, i watched all his videos, and i think i understand what i have to do now
if i find any problems i ll update this thread
thanks everyone
I would've done that because the answer requested the electric field in the three different areas. I was using that as just a suggestion to solve the problem, but maybe I didn't say it was the complete answer but it is for sure a starting point.
Also, Young's book is an algebra based text (at least the copy I have is), so I'm assuming that he doesn't know anything about integrals, hence not suggestion using one.
after some search
because the distribution is not done uniformly
dq = ρ * dv
Qencl = integral(ρ*dv)
Qencl = integral(ρ*4*pi*r^2)dr
what would ρ be here though? in the above video the man says it's k*r but shouldn't it be Q/(4/3*pi*r^3)?
im stuck again...
life can be sucky sometimes :(
You are given [itex]\rho[/itex] in your problem statement...
yes i used it, but again i can't find the correct answer which is
a = 8Q/(5*pi*R^3)
How about showing me your steps then...
integral(0,R/2)ρ*4πr^2dr where ρ i put α from the first equotation, then it's like α*4π*integral(0,R/2)r^2
so Qenclosed will be equals to α*4π*(R^3/8/2)
Qencl = α*4π*(R^3/4) (1)
then i find how much is Q and compare it with Qencl
for Q i just take the integral from 0 to R
and it is Q = α * 4π*(R^3/3)
so Qencl = 3/4*Q
from (1) we have α = (3/4)*Q/4π*(R^3/4)
α = 3*Q/4*π*R^3
sorry for not using latex, i really can't understand how to use it
Also i really appreciate the help you guys are giving me here, thanks
Why are you only integrating from zero to R/2?
[tex]Q=\int_0^\infty \rho(r)4\pi r^2dr=\int_0^{R/2} (\alpha)4\pi r^2dr+\int_{R/2}^R \left(2\alpha\left(1-\frac{r}{R}\right)\right)4\pi r^2dr+\int_R^\infty (0)4\pi r^2dr[/tex]
WOW
THANKS MY FRIEND
WHAT A STUPID MISTAKE I MADE
to calculate Q it took me like 10 minutes, cause it was TOO long, but i FINALLY found the desired result
how can i ++++rep you?
THANKS AGAIN
You're welcome!:smile:
I suppose if you felt so inclined, you could vote for me as homework helper of the year in the annual poll that is posted in 'general discussion', come December:wink: (Shamelessly stumps for votes:biggrin:)
15K
  • · Replies 29 ·
12K
