Thread Closed
A car goes around a vertical circle (Uniform Circular Motion)
Share Thread Thread Tools
Oct30-09, 06:50 PM   #1
A small remote-control car with a mass of 1.51 kg moves at a constant speed of v = 12.0 m/s in a vertical circle inside a hollow metal cylinder that has a radius of 5.00 m.
What is the magnitude of the normal force exerted on the car by the walls of the cylinder at point A (at the bottom of the vertical circle)?
What is the magnitude of the normal force exerted on the car by the walls of the cylinder at point B (at the top of the vertical circle)?
Do I utilize Fnet = ma which would give me 43.488N as Fnet, but I do not see how that would help? I don't know what to do.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct30-09, 06:53 PM   #2
Try drawing a force diagram when the car in at the bottom of the cylinder and when its
at the top of the cylinder.
Oct30-09, 07:04 PM   #3
For Part A, it would just be Fn pointing up and w pointing down.
w=mg so (1.51kg)(-9.8) = -14.798N so Fn must be 14.798N ?
Would part B basically be the same?
Oct30-09, 07:13 PM   #4
F_y = m*a_y
a_y = v^2/r
Does that help?
Oct30-09, 07:13 PM   #5
For part A it should be N - mg = 0, right ? Since mg is pointing down thus N has to be
pointing up.
For part B its not quite the same.
Thread Closed
Thread Tools
Similar Threads for: A car goes around a vertical circle (Uniform Circular Motion)
Thread Forum Replies
Vertical Circular Motion Introductory Physics Homework 11
Vertical Circles and Non-Uniform Circular Motion Introductory Physics Homework 6
Motion in a Vertical Circle (Pendulum) Introductory Physics Homework 1
Vertical Circular Motion Introductory Physics Homework 9
Motion in a vertical circle Introductory Physics Homework 4
