What is the difference between probability and probability density?
The discussion centers on the distinction between probability and probability density, particularly in the context of continuous distributions. Participants explore theoretical explanations and examples, including applications in quantum mechanics.
  • One participant seeks clarification on the concept of probability density and its difference from probability.
  • Another participant explains that probability density represents probability per "area" and is used for events within a continuous distribution, illustrating this with the example of picking a number from the interval [0,1].
  • The same participant notes that the probability of selecting a specific number in a continuous distribution is zero, while the probability of selecting a number within a range can be calculated.
  • They provide a mathematical expression for the radial distribution of the hydrogen atom's 1s orbital, relating it to probability density and probability calculations.
  • Further, they assert that probability can describe events in discrete distributions, while probability density is necessary for continuous systems due to the infinite nature of possible outcomes.
  • A subsequent post confirms that the probability density for finding a number in a specific range within [0,1] is valid due to the uniform distribution of decimals.
  • Another participant acknowledges the need for distribution functions in quantum mechanics, indicating a connection to the broader topic.
Participants generally agree on the definitions and applications of probability and probability density, but there are nuances in the examples and contexts discussed, particularly regarding uniform versus non-uniform distributions.
The discussion does not resolve all aspects of the definitions and applications of probability and probability density, particularly in relation to different types of distributions.
ray.deng83
Like the title, I don't quite understand what probability density is and its difference with probability. Can someone explain a bit on this?
Probability density refers to probably per "area", used to represent probably of an event within a certain interval from a continuous distribution of events. Consider for example an event: randomly picking .50000... from a hat of all real numbers in [0,1]. What's the probability of this event? Zero; 1 in infinity numbers. But what is the probability of picking a number x, such that x<.5000..., from [0,1]. One half, of course. That's a probability density.
So, the radial distribution of the hydrogen atom 1s orbital
[tex]P(r) = 4\pi r^{2}\psi_{100}[/tex]
gives a distribution of probabilties of finding an electron at a radius r. Probability is then
[tex]P=\int_{a}^{b}4\pi r^{2}\psi_{100} \,dr[/tex]
on the radial interval [a,b].
So, probability can be used to describe an event within a discrete distribution which has finite entities and probability density is for an interval in a continuous system. This is because there are infinite entities in a continuous system and any probability of finding a specific one is zero and hence we have to use probability density to describe it.
In this sense, for that example, can we say the probability density of finding a number x, such that 0.3<x<0.5 from [0,1] is (0.5-0.3)/1?
Yes, because the distribution of decimals in [0,1] is uniform. In quantum mechanics we commonly deal with non-uniform wavefunctions.
Yes and that's why we need those distribution functions. Thanks for your help!
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 21 ·
