Inertia in motion - why is momentum called this
The discussion revolves around the terminology of momentum being referred to as "inertia in motion." Participants explore the origins and implications of this phrase, as well as the concept of conservative forces in nature.
  • Some participants question why momentum is referred to as "inertia in motion," seeking clarification on the terminology.
  • One participant notes that momentum is defined as p=mv and remains constant in an inertial reference frame if no forces act on the particle.
  • Another participant expresses skepticism about the phrase "inertia in motion," arguing it is ambiguous and does not accurately represent the concept of momentum.
  • Several participants mention that they have heard the term used metaphorically but do not find it to be a precise description of momentum.
  • A participant humorously suggests that the term "inertia" could have other connotations, including its literal meaning of laziness.
  • One participant proposes a playful alternative name for momentum, "floogum," indicating a lighthearted take on the discussion.
  • Discussion also touches on angular momentum, with a participant referencing its relationship to moment of inertia and angular velocity.
  • Another participant challenges the validity of the term "inertia in motion," asking for a source to support its usage.
Participants do not reach a consensus on the appropriateness of the term "inertia in motion" for momentum. Multiple competing views are presented regarding its accuracy and usefulness.
Some participants express uncertainty about the origins of the term and its acceptance in the scientific community. There are also references to the metaphorical nature of the phrase, which may not align with formal definitions.
Kaxa2000
Inertia in motion - why is momentum referred to as this?
Also, what forces in nature are conservative does anyone know any examples?
Referred as what?
All of them.
Why's it referred to as "inertia in motion"
Where did you read that?
The Linear momentum of a particle is defined as p=mv. It is a quantity that remains constant with respect to an inertial reference frame, if no forces act on the particle.
It's also called inertia in motion
I have never read or heard this anywhere. The only reason I see for somebody using this, is because mass is sometimes called a measure of inertia.If a mass is in motion it has momentum. I think it is an ambiguous and useless way to describe momentum. You should try to understand the usual definition.
I've heard of momentum being referred to, metaphorically, as "inertia in motion". I don't think it's accurate, even as a lie-to-children, because it doesn't represent how hard it is to move the object.
This sounds like an old usage. Where did you read it?
Inertia in motion alright. Inertia in what else? I have once read that "inertia" literally means laziness. Maybe this has got something to do with it.
Inertia would also be a fantastic name for a female. Wonder why no one has chosen it yet. :D
(a) somebody decided to call it that,
(b) somebody did not like momentum,
(c) somebody is pulling your leg. (fooling you)
Let's call it "floogum" from now on...
if you look at angular momentum
angular momentum = moment of inertia x angular velocity
where moment of inertia is the distribution of mass
It isn't! :smile:
(Unless you can produce a quote …)
  • · Replies 30 ·
  • · Replies 60 ·
  • · Replies 21 ·
  • · Replies 35 ·
