How Can I Solve x^2-xy+y^2+x+y+1=0 for My Math Project?
  • Thread starter Thread starter AlanZa
The equation x^2 - xy + y^2 + x + y + 1 = 0 can be analyzed as a quadratic in y, allowing for solutions via the quadratic formula. The original equation x^3 + 3xy + y^3 = 1 can be factored into (x + y - 1)(x^2 - xy + y^2 + x + y + 1) = 0, where the first factor represents a line at a 45-degree angle. The discriminant of the quadratic equation determines the nature of the graph; a negative discriminant indicates no real solutions, while a positive one provides a formula for y. Expanding the expression (1/2)((x-y)^2 + (x+1)^2 + (y+1)^2) may also yield insights into the problem.
  • Understanding of quadratic equations and the quadratic formula
  • Familiarity with factoring polynomials
  • Knowledge of discriminants and their implications on graphing
  • Basic algebraic manipulation skills
  • Study the quadratic formula and its application in solving quadratic equations
  • Learn about discriminants and how they affect the nature of solutions
  • Explore polynomial factoring techniques for higher-degree equations
  • Investigate graphing techniques for quadratic equations in two variables
Students in Intermediate Algebra, math enthusiasts, and anyone working on graphing quadratic equations or solving polynomial equations.
AlanZa
I need help with this Problem x^2-xy+y^2+x+y+1=0. It is part of a math project I am doing to plot a graph. The original problem was x^3+3xy+y^3=1 can factor and it plots a line at a 45 degree angle. The first part of the factorization is x+y-1=0. The only thing I can figure to do with the problem is to take the +1 and move it to the otherside of the = and make it -1 so I have a point to work with other than 0. The only number I have found that will equal -1 is to have both x and y as -1. Any help would be gladly received. Thanks for your time.
P.S. I am only in Intermediate Algerbra so please make it so I can understand.
You started with your original equation:
x3+3xy+y3 - 1 = 0
and factored it to get:
(x + y - 1)(x2 -xy+y2+x+y+1) = 0
and have used the first factor to get the straight line. So your remaining problem is to see if the other factor gives you anything:
x2- xy+y2+x+y+1 = 0
This is a quadratic equation in y which you can solve by the quadratic formula. So collect terms on powers of y and look at the discriminant of that quadratic equation. If the discriminant is negative you get no graph. If it is positive the quadratic formula will give you a formula for y.
If you're confused with what to do with the quadratic, as an alternative, try expanding:
[tex]\frac{1}{2}\left((x-y)^2+(x+1)^2+(y+1)^2\right)[/tex]
and see if you can deduce anything from that.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 24 ·
