How Fast Does the Ladder Slide Down the Wall?
  • Thread starter Thread starter ladyrae
    Differentiation
The discussion revolves around related rates problems in calculus, specifically involving a ladder sliding down a wall and a rocket being tracked by radar. Participants are exploring how to apply differentiation and the Pythagorean Theorem to find rates of change in these scenarios.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to establish the relationship between the lengths involved in the ladder problem and seeks clarification on the equation needed. Another participant suggests using the Pythagorean Theorem and differentiation to derive the necessary rates. A similar approach is proposed for the rocket problem, emphasizing the importance of understanding the variables involved.
Participants are actively discussing the application of differentiation to solve the problems presented. Some guidance has been offered regarding the use of the Pythagorean Theorem and the need to clarify what variables represent. There is an emphasis on the importance of showing prior attempts to facilitate further assistance.
Participants note that they can provide help only if the original poster shares their attempts and where they are encountering difficulties. This suggests a focus on collaborative problem-solving rather than direct solutions.
ladyrae
Use differentiation to solve the following
A ladder 25 feet long is leaning against the wall of a house. The base of the ladder is pulled away from the wall at rate of 2 feet per second. How fast is the top moving down the wall when the base of ladder is 15 feet from the wall.
What's the equation?
Thanks
Use the Pythagorean Theorem.
[tex]x^2 + y^2 = z^2[/tex]
Diffentiate:
[tex]x\frac{dx}{dt} + y \frac{dy}{dt} = z\frac{dz}{dt}[/tex]
Solve for the desired variable, dy/dt in this case
[tex]\frac{dy}{dt} = \frac{z\frac{dz}{dt} - x\frac{dx}{dt}}{y}[/tex]
Plug in values you know, using x^2 + y^2 = z^2 to determine distances you don't.
cookiemonster
how about this one
Using Differentiation solve
a rocket is launched vertically and is tracked by a radar station located on the ground 12 kilometers from the launch site. When the rocket is 20 km away from the radar station, its distance from the station is increasing at the rate of 2500 km/hr. What is the vertical speed of the rocket at this instant?
What is the equation?
Thanks
Same approach as the previous problem. Now you know x, y and can find z from Pyth. What is important is understanding what dx/dt and dy/dt are equal to.
Typically, we can help you only if you show us what you have tried and where you are stuck. We are not here to provide solutions to your homework.
